Community Member
GW not registering on a GK
I`ve 2 GKs and a group of 10 GWs that I'm cofiguring to register against the GKs.
I've configured ok 3 GWs, but when I configure the fourth it doesn't register. The configuration is the same on this GW.
This is the configuration for a GW that is registered with the GK
interface Ethernet0/0
ip address 10.180.67.200 255.255.255.0
half-duplex
fair-queue
h323-gateway voip interface
h323-gateway voip id gk01.demo.cl ipaddr 10.179.200.20 1719 priority 120
h323-gateway voip id gk02.demo.cl ipaddr 10.177.50.20 1719
h323-gateway voip h323-id gw_talca
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr 10.180.67.200
Talca#sh gatew
Gateway gw_talca is registered to Gatekeeper gk01.demo.cl
Alias list (CLI configured)
H323-ID gw_talca
Alias list (last RCF)
H323-ID gw_talca
H323 resource thresholding is Disabled
Permanent Alternate Gatekeeper List
priority 120 id gk01.demo.cl ipaddr 10.179.200.20 1719 register needed
priority 127 id gk02.demo.cl ipaddr 10.177.50.20 1719 register needed
Primary gatekeeper ID gk01.demo.cl ipaddr 10.179.200.20 1719
2.- This is the configuration of the Gw that doesn't register:
ip address 10.180.65.200 255.255.255.0
full-duplex
fair-queue
h323-gateway voip h323-id gw_concepcion_2
h323-gateway voip bind srcaddr 10.180.65.200
sh gatew
Gateway gw_concepcion_2 is not registered to any gatekeeper
H323-ID gw_concepcion_2
Alias list (last RCF) is empty
Non Permanent Alternate Gatekeeper List
3) This is the configuration on GK01
gatekeeper
zone local gk01.demo.cl demo.cl 10.179.200.20
zone remote gk02.demo.cl demo.cl 10.177.50.20 1719
zone prefix gk01.demo.cl 31.. gw-priority 10 gw_talca
zone prefix gk01.demo.cl 32.. gw-priority 10 gw_chillan
zone prefix gk01.demo.cl 37.. gw-priority 10 gw_osorno
gw-type-prefix 1#* default-technology
no shutdown
GK-1#sh gatek end
GATEKEEPER ENDPOINT REGISTRATION
CallSignalAddr Port RASSignalAddr Port Zone Name Type Flags
10.180.18.200 1720 10.180.18.200 53275 gk01.demo.cl VOIP-GW
H323-ID: gw_osorno
Voice Capacity Max.= Avail.= Current.= 0
10.180.66.200 1720 10.180.66.200 54543 gk01.demo.cl VOIP-GW
H323-ID: gw_chillan
10.180.67.200 1720 10.180.67.200 53931 gk01.demo.cl VOIP-GW
H323-ID: gw_talca
Total number of active registrations = 3
I've tried shutting down the GK01, and the 3 GWs registers against GK02. Then starting GK01 and the same 3 GWs register against it.
Ì've tried with 2 different gateways,and they didn't register. Only the same 3 GWs.
GK is running c2800nm-ipvoice_ivs-mz.124-8.bin
Any suggestion will be glad received.
TIA
Andres Pasten
1 ACCEPTED SOLUTION
Green
Re: GW not registering on a GK
Hi Andres,
Perfomr a debug h225 asn1 in the GW which is failing also in GK
Do a no gateway, then gateway in config mode
Make sure u can ping from src IP
10.180.65.200
to 10.179.200.20
and let us know
Green
Hi Andres,
10.180.65.200
to 10.179.200.20
and let us know
Community Member
When I've done a no gateway and then gateway, the gateway has registered on the GK. I've tested it on 2 GWs and worked fine.
So now I'm intrigued why I was able to register the first 3 GWs if I've not done the "no gateway/gateway".
TIA
Andres
Community Member
I'm trying a scenario of 2 GW's and a GK
Am able to register 1 GW without any issues
the other one is not registering tried no gateway/gateway and debug h225 asn1 & debug ras doesnt gives any output, Able to ping from source IP's
Attached is the config i'm trying
Community Member
On the GK config, the zone local defines the GK name and his IP Address, not the GWs names.
So if the names and IP's are this way:
IP Name
30.1.1.3 GK.cisco.com
30.1.1.1 Boise
30.1.1.2 Miami
The configs should be:
a) GK
gatekeeper
zone local GK.cisco.com cisco.com 30.1.1.3
no shutdown
b)Boise
BoiseGW-Config
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip address 30.1.1.1 255.255.255.0
no snmp trap link-status
h323-gateway voip id GK.cisco.com ipaddr 30.1.1.3 1719
h323-gateway voip h323-id boise@cisco.com
h323-gateway voip bind srcaddr 30.1.1.1
c) Miami
interface GigabitEthernet0/0.1
description TO-GK
ip address 30.1.1.2 255.255.255.0
h323-gateway voip h323-id miami@cisco.com
h323-gateway voip bind srcaddr 30.1.1.2
See you.
Andres Pasten
Adexus S.A.
Community Member
Its so kind of you i had done the replica of the config you provided, it was not registering then also tried adding the session target ras(as per other netpro) in miami, It got registerd
4 points to u
Thank u
254
