GW translation-rule question: match called - modify calling
Does anyone know if it is possible to modify the calling number type based on a match on the called number?
Example:
Calling number: 46701234567 (Type: International)
Called number: 98089512345 (Type: Unknown)
The calling number type should be changed to 'Unknown' if the called number matches with the regular expression ^980895.*
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: GW translation-rule question: match called - modify calling
No, that is not possible with a translation-rule.
However, you can use an incoming DP to prefix the called number with somethign in order to route the call out to a designated outgoing DP, where the correct type is applied.
An alternative option might be to use a dial-peer with 'incoming called-number 980895.....' to match on the inbound leg of the call, and then apply a voice translation profile to that dial-peer to set the calling number type to 'Unknown'.
Michael.
That is exactly what I was saying above in different words :)
Thanks Paolo & Michael, that might just work.
Something like this?
voice translation-rule 1
rule 1 // // type any unknown
voice translation-profile MODIFY
translate calling 1
dial-peer voice 20 pots
translation-profile outgoing MODIFY
incoming called number 980895.T
direct-inward-dial
forward digits all
port 0/0/0:15
Looks good, except the profile should be applied in the inbound direction. The direction is from the perspective of the gateway.
Michael.
135
