Community Member
H.323 and MGCP configuration on the same VG
I have a 3845 voice gateway that connects to both PBX and PSTN via 4 E1 ports (2 for the PBX & 2 for the PSTN). Is it possible to configure the 2 pri ports connecting to the pbx as mgcp gw and the 2 pri ports connecting to the pstn as H.323 gw?
Do you see any issue with this implementation?
The ccm version is 6.1
Thanks in advance.
Hall of Fame Super Silver
Re: H.323 and MGCP configuration on the same VG
This is absolutely OK as long as you dont control the same port with both protocols. I've done this several times without issues.
HTH,
Chris
Community Member
Thanks a lot
111
