H.323 and MGCP Gateway
Hello Guys,
I just need a confirmation on this question: Can a single router (3845) be configured for both H.323 and MGCP Gateways?
Thank you.
  • IP Telephony
Blue
Yes you can configure it.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Re: H.323 and MGCP Gateway
Thank you Ronak.
The issue is that I have been trying to configure an FXS port connected to an analogue telephone line. I ghave done the MGCP and CUCM configuration.
When I called the analogue number from a Cisco Phone, it is ringing but not heard on the analogu phone. If the analogue phone is off hook, there is no dialing tone.
Anyone with a possible solution should kindly assist.
Thank you.
Please post the FXS port config. Running config of router would be great to have.
GP.
Find below the router configuration:
Building configuration...
Current configuration : 12511 bytes
! No configuration change since last restart
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service compress-config
service sequence-numbers
boot-start-marker
boot system flash:c3845-ipvoicek9-mz.124-25f.bin
boot system tftp )# 255.255.255.255
boot system tftp c3845-ipvoice-mz.124-24.T3.bin 192.168.20.131
boot-end-marker
aaa new-model
aaa authentication login default group tacacs+ line enable
aaa authentication enable default group tacacs+ enable
aaa authorization config-commands
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting update newinfo
aaa session-id common
clock timezone GMT 1
network-clock-participate wic 0
network-clock-participate wic 2
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/2/0
no ip source-route
ip cef
no ip domain lookup
ip domain name ng.sbicdirectory.com
isdn switch-type primary-qsig
voice-card 0
no dspfarm
voice service voip
h323
voice class codec 1
codec preference 1 g711alaw
codec preference 3 g729r8
codec preference 4 g711ulaw
voice class h323 1
h225 timeout setup 30
archive
log config
  hidekeys
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/2/0
interface Loopback0
ip address 192.168.253.73 255.255.255.255
interface GigabitEthernet0/0
description ******** CONNECTION TO IDEJO SERVER FARM LAN ********
ip address 192.168.20.10 255.255.255.0
duplex half
speed 100
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
interface Serial0/2/0:15
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/0/0:15
voice-port 0/2/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
ccm-manager fallback-mgcp
ccm-manager redundant-host 192.168.10.17
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.10.9
ccm-manager config
mgcp
mgcp call-agent 192.168.10.9 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability gm-package
no mgcp package-capability dtmf-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 1 voip
destination-pattern 7...
session target ipv4:192.168.10.9
dtmf-relay h245-alphanumeric
codec g711alaw
dial-peer voice 30 pots
destination-pattern 0
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 60 voip
destination-pattern 6...
codec g711alaw
dial-peer voice 5 voip
destination-pattern 5...
codec g711alaw
dial-peer voice 101 pots
destination-pattern 9T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/2/0:15
dial-peer voice 7470 pots
service mgcpapp
port 0/1/1
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1
Blue
Please use service MGCPAPP and not service mgcpapp. It is case sensitive.
Ronak Patel
368
