H.323 Caller ID issue
I've just set up an H.323 gateway with a CUCM 6.0 server. Calls seem to be working fine, but caller ID is not displaying on inbound calls via 1MB lines.
I've found what I believe I need to do, which is:
At the voice service level:
voice service voip
h323
h225 timeout ntf <50-5000>
h225 display-ie ccm-compatible
At the voice class level:
voice class h323 1
h225 display-ie ccm-compatible [system]
interface Serial0/3/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn map address *. plan isdn type unknown
isdn supp-service name calling
no cdp enable
However, the voice service and voice class options aren't available on my router, and this is for 1MB lines, so the serial config doesn't apply.
What am I missing? I'm running IOS 12.4(9)T7
Thanks in advance
1 REPLY
Re: H.323 Caller ID issue
I figured it out. I have to upgrade the IOS.
Please disregard post.
182
