H.323 client windows netmeeting
Hi;
I configured voice gateway for gatekeeper functions and installed windows netmeeting. I configured netmeeting to register gatekeeper. Then i configured call manager for this issue. Now; ip phones can call netmeeting however netmeeting can not call ip phones. CM doesn't let me call.
1 REPLY
Silver
Re: H.323 client windows netmeeting
Set the bandwidth on netmeeting as LAN and this will allow you to select G711ulaw as the main codec under the advanced audio settings.
It's likely you are using the Netmeeting default G723 codec and CallManager is having a problem with this - the 79XX phones only support G729 and G711.
304
