Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
H.323 CUCM support
I have a working call manager version 4.1 and i will upgrade soon to version 6.1, I just need to know if I have to upgrade cisco h.323 router gateways and VG200 which are contacted through H.323 only.
Green
Re: H.323 CUCM support
should work, depending the IOS u have, I would use the cucm compatibility matrix to make sure ur using at least the version stated there.
You can take a look at this doc for versions tested with each version:
Cisco Unified Communications System Release Summary Matrix for IP Telephony for Enterprise and Midmarket
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/unified/communications/system/versions/IPTMtrix.html#wp1016708
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
what about third party H323 gateways?
232
