Silver
H.323 forward digits
I have h323 gateway connected to CO isdn switch. when a public user dials the FQDN the h323 gateway sees the call coming in showing 6digits which is fine, but i would like to strip a further two digits from the start of the number, before forwarding the inbound call. How should this be achieved?
Ajaz
Re: H.323 forward digits
OK, I understand the following scenario:
PSTN --> CO --> H.323 --> ...
What is receiving the final 4 digits, the CCM server? if yes, then you can just set the Significant Digits field to 4 under Inbound Calls, this is done on the GW configuration page in CCM.
If something else is used then you could use a translation rule on the GW.
//Jorge
Silver
Jorge
The q931 incoming call set-up message displays 6digits called number - the CO switch done some digit stripping from the dialled E.164 number and I don't have a problem with that. Now, i would like to forward the last four digits to ccm. So, i need to strip the two left most digits before the call is forwarded.
i can see few option. num-exp, trans rule or forward-digits?
i have already tested num-exp but it is globally applied as you know. This does the job, however, imo this is not the most elegant solution.
Ajaz
Anonymous
N/A
If you are sending these digits to CCM, you can set the significant digits on the inbound call for the gateway/trunk to 4.
To strip the digits in the gateway, use tranlation-rules
http://cisco.com/en/US/partner/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a008086f2e2.html
162
