Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
H.323 Gateway and Analog Trunks
CallManager 6 with an H.323 gateway(2610 Router with a 2 port FXO card). Analog phone line is connected to the FXO port. I am trying to route the call to an 7940 phone with extension 1000 that is registered to the callmanager. When an incoming call is placed through the analog line, the outside party hears one ring and a dial-tone. I have 2 dial-peers configured on the gateway,
dial-peer voice 100 pots
incoming called-number .
port 1/1/0
***also added the direct-inward-dial, but didn't make any difference.
dial-peer voice 1000 voip
destination-pattern 1000
session target ipv4:192.168.10.10 (IP of the CCM Publisher)
I also tried adding the connection plar 1000 on the voice-port 1/1/0, still the callers gets dial-tone.
I am suspecting that the problem is with my dial-peer 100, I am just not sure if the incoming called-number . can be used since I am not getting any digits from Telco like a DID call. Anyone has any idea how this should be configured, please help. I also have the debug voice ccapi inout attached.
1 ACCEPTED SOLUTION
Re: H.323 Gateway and Analog Trunks
Im a bit confused. You have posted the config of your router and not the debug output. But in looking at the config you posted, I dont see dial peer 1000, but I do see a voip dial peer that has a destination pattern of 1000 pointing to CUE. However, your config should look something like this:
voice-port 1/1/0
dtmf-relay h245-alphanumeric
inteface FastEthernet0/1.10
h323-gateway voip-interface
h323-gateway voip srcaddress (IP of h323 gateway in ccm)
Hope that helped, if so please rate.
voice-port 1/1/0
Sorry, I had the wrong file attached, attching the correct file. I will try what Ken had suggested and will post the results.
Also you can do "debug voip dialpeer all" to be sure that the call is hitting the correct dialpeer.
The reason you're getting dial tone is that you're hitting dial peer 0. Dial peer 0 is matched when there is no other dial peer to match.
145
