Community Member
H.323 gateway FXO incoming calls not working.
I have a CUCM 6 and a 2621XM with NM-2V and VIC-2FXO. The router is configured as a H.323 gateway as shown below. Outgoing calls from 8001 are working fine. However, incoming calls (which should all be forwarded to 8001) are not working. It keeps on ringing from the calling phone, but the actual 8001 is not ringing at all. In CUCM config, the router is defined and associated with a CSS able to reach 8001. Also attached is some debug result.
Any idea?
Andrew
voice-port 1/0/0
trunk-group FXOTrunkGroup
cptone AU
connection plar opx 8001
voice-port 1/0/1
cptone AU
connection plar 8001
dial-peer voice 10 pots
trunkgroup FXOTrunkGroup
destination-pattern 0[2-8]........
forward-digits all
dial-peer voice 100 voip
destination-pattern 8001
session target ipv4:10.8.8.80
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
#sh voice port summ
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
1/0/0           --  fxo-ls      up    dorm idle     on-hook  y
1/0/1           --  fxo-ls      up    dorm idle     on-hook  y
PWR FAILOVER PORT        PSTN FAILOVER PORT
#sh dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT
10     pots  up   up             0[2-8]........     0                      up   trunkgroup FXOTrunkGroup
100    voip  up   up             8001               0  syst ipv4:10.8.8.80
#sh dialplan num 8001
Macro Exp.: 8001
VoiceOverIpPeer100
        peer type = voice, information type = voice,
        description = `',
        tag = 100, destination-pattern = `8001',
        answer-address = `', preference=0,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 100, Admin state is up, Operation state is up,
        incoming called-number = `', connections/maximum = 0/unlimited,
        DTMF Relay = enabled,
        modem transport = system,
        URI classes:
            Incoming (Called) =
            Incoming (Calling) =
            Destination =
        huntstop = disabled,
        in bound application associated: 'DEFAULT'
        out bound application associated: ''
        dnis-map =
        permission :both
        incoming COR list:maximum capability
        outgoing COR list:minimum requirement
        Translation profile (Incoming):
        Translation profile (Outgoing):
        incoming call blocking:
        translation-profile = `'
        disconnect-cause = `no-service'
        advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
        type = voip, session-target = `ipv4:10.8.8.80',
        technology prefix:
        settle-call = disabled
        ip media DSCP = ef, ip signaling DSCP = af31,
        ip video rsvp-none DSCP = af41,ip video rsvp-pass DSCP = af41
        ip video rsvp-fail DSCP = af41,
        UDP checksum = disabled,
        session-protocol = cisco, session-transport = system,
        req-qos = best-effort, acc-qos = best-effort,
        req-qos video = best-effort, acc-qos video = best-effort,
        req-qos audio def bandwidth = 64, req-qos audio max bandwidth = 0,
        req-qos video def bandwidth = 384, req-qos video max bandwidth = 0,
        dtmf-relay = h245-alphanumeric,
        RTP dynamic payload type values: NTE = 101
        Cisco: NSE=100, fax=96, fax-ack=97, dtmf=121, fax-relay=122
               CAS=123, ClearChan=125, PCM switch over u-law=0,A-law=8
               G726r16 using static payload
               G726r24 using static payload
        RTP comfort noise payload type = 19
        fax rate = voice,   payload size =  20 bytes
        fax protocol = system
        fax-relay ecm enable
        fax NSF = 0xAD0051 (default)
        codec = g711ulaw,   payload size =  160 bytes,
        Media Setting = flow-through (global)
        Expect factor = 10, Icpif = 20,
        Playout Mode is set to adaptive,
        Initial 60 ms, Max 250 ms
        Playout-delay Minimum mode is set to default, value 40 ms
        Fax nominal 300 ms
        Max Redirects = 1, signaling-type = cas,
        VAD = disabled, Poor QOV Trap = disabled,
        Source Interface = NONE
        voice class sip url = system,
        voice class sip rel1xx = system,
        redirect ip2ip = disabled
        probe disabled,
        voice class perm tag = `'
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 4642, Charged Units = 0,
        Successful Calls = 0, Failed Calls = 44, Incomplete Calls = 0
        Accepted Calls = 5, Refused Calls = 0,
        Last Disconnect Cause is "10  ",
        Last Disconnect Text is "normal call clearing (16)",
        Last Setup Time = 17181509.
Matched: 8001   Digits: 4
Target: ipv4:10.8.8.80
1 REPLY
Community Member
Re: H.323 gateway FXO incoming calls not working.
From the debug, I can see the H.225 communications between the CUCM and the gateway. The call was released with disconnect cause 1.
"H323/release_ind: Disconnect cause 1 location code 0"
According to cisco documentation, it means "Unallocated (unassigned) number. This cause indicates that the destination requested by the calling user cannot be reached because the number is unassigned. This number is not in the routing table, or it has no path across the ISDN network".
Extension 8001 is definitely working, I can call it from 8002 internally.
Any idea?
Andrew
2168
