H.323 gateway incomming calls on FXO ports
I have an H.323 gateway with CM 4.1. Calls are going out and comming in fine. However, I changed the plar command on the voice port to plar to a diffrent extension. I updated the corresponding dial-peer, but it is not working. Calls can still come in on other ports and go out, but they are just not working on the port I changed the plar for.
Is there something I need to reset for this to work. I verified that the CSS and partition is not the issue. I can call the same DN from a phone in the same partition and CSS. I tried reseting the CTI route point, but that did not work. I verified that the dial-peer is being hit, but I just get a busy signal immediatly once the call hits the gateway.
voice-port 0/1/0
supervisory disconnect dualtone mid-call
echo-cancel coverage 32
timing hookflash-out 500
connection plar 1751
description *** 377-6965 ***
caller-id enable
dial-peer voice 20 voip
preference 1
destination-pattern 1751
session target ipv4:10.150.152.6
dtmf-relay h245-alphanumeric
no vad
1 REPLY
Anonymous
N/A
Re: H.323 gateway incomming calls on FXO ports
The connection plar command needs to be configured on all of the voice-ports.Change the configuration to slow start so that it will work.
138
