H.323 gateway not sending disconnect message
Hi All,
I have configured a new E1 and associated DID range.
I am getting ring back for unallocated numbers.There is no matching pattern exist and debug showing unallocated number error.But still I can gett the ring back tone from PSTN.
It seems gateway is not sending the disconnect message.
Please help me how to check that.
Apr 21 11:49:32 BST: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Progress Ind i = 0x8483 - Origination address is non-ISDN
        Calling Party Number i = 0x00C3, N/A
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0xA1, '349509'
                Plan:ISDN, Type:National
        Low Layer Compat i = 0x9090A3
Apr 21 11:49:32 BST: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8                                             001
Apr 21 11:49:32 BST: ISDN Se0/0/0:15 Q931: TX -> PROGRESS pd = 8  callref = 0x80                                             01
        Cause i = 0x8181 - Unallocated/unassigned number
        Progress Ind i = 0x8188 - In-band info or appropriate now available
Apr 21 11:49:35 BST: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x904                                             C
Apr 21 11:49:35 BST: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0                                             x104C
Apr 21 10:51:25 BST: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
Sending Complete
Standard = CCITT
Apr 21 10:51:25 BST: //-1/5623EE478B9D/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=90
   cisco-anitype=2
   cisco-aniplan=0
   cisco-anipi=2
   cisco-anisi=3
   dest=349509
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Apr 21 10:51:25 BST: //-1/5623EE478B9D/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4844FC14, Call Info(
   Calling Number=90,(Calling Name=)(TON=National, NPI=Unknown, Screening=Network, Presentation=Unavailable),
   Called Number=349509(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=9, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Apr 21 10:51:25 BST: //-1/5623EE478B9D/CCAPI/ccCheckClipClir:
   In: Calling Number=90(TON=National, NPI=Unknown, Screening=Network, Presentation=Unavailable)
   Out: Calling Number=90(TON=National, NPI=Unknown, Screening=Network, Presentation=Unavailable)
Apr 21 10:51:25 BST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 21 10:51:25 BST: :cc_get_feature_vsa malloc success
Apr 21 10:51:25 BST:  cc_get_feature_vsa count is 11
Apr 21 10:51:25 BST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1207650424,feature_id:18228
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=90(TON=National, NPI=Unknown, Screening=Network, Presentation=Unavailable),
   Called Number=349509(TON=National, NPI=ISDN))
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_process_call_setup_ind:
   Event=0x47FC45B0
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccCallSetContext:
   Context=0x48A646A4
   >>>>CCAPI handed cid 18228 with tag 9 to app "_ManagedAppProcess_Default"
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=349500, Params=0x48A6725C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccCheckClipClir:
   Destination Pattern=349..., Called Number=349509, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=5623EE47-C871-11E3-8B9D-001EBE027FE0, Outgoing Dial-peer=349500
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=90
   cisco-anitype=2
   cisco-aniplan=0
   cisco-anipi=2
   cisco-anisi=3
   dest=349509
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x47D29438, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=90,(Calling Name=)(TON=National, NPI=Unknown, Screening=Network, Presentation=Unavailable),
   Called Number=349509(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=349500, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Apr 21 10:51:25 BST:  cc_get_feature_vsa count is 12
Apr 21 10:51:25 BST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1207658416,feature_id:18229
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/ccCallSetContext:
   Context=0x48A6720C
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccSaveDialpeerTag:
Apr 21 10:51:25 BST: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8001
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/cc_api_call_proceeding:
   Interface=0x47D29438, Progress Indication=NULL(0)
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/cc_api_call_cut_progress:
   Interface=0x47D29438, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=1
   Call Entry(Responsed=TRUE)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=1
   Voice Call Send Alert=FALSE, Call Entry(AlertSent=FALSE)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=18228
Apr 21 10:51:25 BST: //18228/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x45BEF84C, callID1=0x4734, callID2=0x4735, tag=0x0)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccConferenceCreate:
   Conference Id=0x45BEF84C, Call Id1=18228, Call Id2=18229, Tag=0x0
Apr 21 10:51:25 BST: //18228/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2105, Source Interface=0x4844FC14, Source Call Id=18228,
   Destination Call Id=18229, Disposition=0x0, Tag=0xFFFFFFFF
Apr 21 10:51:25 BST: //18229/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Apr 21 10:51:25 BST: cc_api_get_xcode_stream : 4381
Apr 21 10:51:25 BST: //18229/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2105, Source Interface=0x47D29438, Source Call Id=18229,
   Destination Call Id=18228, Disposition=0x0, Tag=0x0
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x2105, Destination Call Id=18229)
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2105, Destination Call Id=18228)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_api_caps_ind:
   Destination Interface=0x47D29438, Destination Call Id=18229, Source Call Id=18228,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=250(ms), Fax Nom=300(ms))
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2105, Call Id1=18228, Call Id2=18229
Apr 21 10:51:25 BST: ISDN Se0/1/0:15 Q931: TX -> PROGRESS pd = 8  callref = 0x8001
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4844FC14, Destination Call Id=18228, Source Call Id=18229,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7129)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_api_caps_ack:
Usually you would expect the
Usually you would expect the carrier to send a Disconnect message in response to the progress message with unallocated number.
There may be a way to convert the progress message to a disconnect message but I can't remember off the top of my head.
Try this...voice call disc-pi
Try this...voice call disc-pi-off
I have added that command but
I have added that command but no luck,still getting ring back for unallocated numbers
Apr 24 15:29:02 BST: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0002
Sending Complete
Standard = CCITT
Channel ID i = 0xA98382
Exclusive, Channel 2
Called Party Number i = 0xA1, '349544'
Apr 24 15:29:02 BST: //-1/9D9896348D5D/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=90
   cisco-anitype=2
   cisco-aniplan=0
   cisco-anipi=2
   cisco-anisi=3
   dest=349544
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr 24 15:29:02 BST: //-1/9D9896348D5D/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x475EB9D4, Call Info(
   Called Number=349544(TON=National, NPI=ISDN),
Apr 24 15:29:02 BST: //-1/9D9896348D5D/CCAPI/ccCheckClipClir:
Apr 24 15:29:02 BST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 24 15:29:02 BST: :cc_get_feature_vsa malloc success
Apr 24 15:29:02 BST:  cc_get_feature_vsa count is 131
Apr 24 15:29:02 BST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1220009056,feature_id:31202
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=349544(TON=National, NPI=ISDN))
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/cc_process_call_setup_ind:
   Event=0x471BA208
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccCallSetContext:
   Context=0x48CCFD14
   >>>>CCAPI handed cid 31204 with tag 9 to app "_ManagedAppProcess_Default"
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccCallProceeding:
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=349500, Params=0x488C3E80, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccCheckClipClir:
   Destination Pattern=349..., Called Number=349544, Digit Strip=FALSE
   Guid=9D989634-CAF3-11E3-8D5D-001BD4391750, Outgoing Dial-peer=349500
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=90
   cisco-anitype=2
   cisco-aniplan=0
   cisco-anipi=2
   cisco-anisi=3
   dest=349544
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x46CC1C84, Interface Type=1, Destination=, Mode=0x0,
   Called Number=349544(TON=National, NPI=ISDN), Calling Translated=FALSE,
Apr 24 15:29:02 BST:  cc_get_feature_vsa count is 132
Apr 24 15:29:02 BST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1220018776,feature_id:31203
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/ccIFCallSetupRequestPrivate:
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/ccCallSetContext:
   Context=0x488C3E30
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccSaveDialpeerTag:
Apr 24 15:29:02 BST: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8002
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/cc_api_set_called_ccm_detected:
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/cc_api_call_proceeding:
   Interface=0x46CC1C84, Progress Indication=NULL(0)
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/cc_api_call_cut_progress:
   Interface=0x46CC1C84, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=1
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccCallCutProgress:
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=31204
Apr 24 15:29:02 BST: //31204/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4877D144, callID1=0x79E4, callID2=0x79E5, tag=0x0)
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccConferenceCreate:
   Conference Id=0x4877D144, Call Id1=31204, Call Id2=31205, Tag=0x0
Apr 24 15:29:02 BST: //31204/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x36BB, Source Interface=0x475EB9D4, Source Call Id=31204,
   Destination Call Id=31205, Disposition=0x0, Tag=0xFFFFFFFF
Apr 24 15:29:02 BST: //31205/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Apr 24 15:29:02 BST: cc_api_get_xcode_stream : 4381
Apr 24 15:29:02 BST: //31205/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x36BB, Source Interface=0x46CC1C84, Source Call Id=31205,
   Destination Call Id=31204, Disposition=0x0, Tag=0x0
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x36BB, Destination Call Id=31205)
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x36BB, Destination Call Id=31204)
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46CC1C84, Destination Call Id=31205, Source Call Id=31204,
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x36BB, Call Id1=31204, Call Id2=31205
Apr 24 15:29:02 BST: ISDN Se0/1/0:15 Q931: TX -> PROGRESS pd = 8  callref = 0x8002
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/cc_api_caps_ind:
   Destination Interface=0x475EB9D4, Destination Call Id=31204, Source Call Id=31205,
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/cc_api_caps_ack:
Try ..voice call send-alert
Try ..voice call send-alert in global config.
Hi Saif, Do u remember how u
Hi Saif,
Do u remember how u resolved this issue, am facing the same issue
Hi.To add a tip to what
Hi.
To add a tip to what correctly suggested by Manish (+5), on outgoing dialpeer try to add:
progress_ind setup enable 3
progress_ind alert enable 8
Carlo
Please rate all helpful posts "The more you help the more you learn"
VIP Super Bronze
In addition to everything
In addition to everything that my honourable friends have said here, I just wanted to point out the ff:
1. Its not the provider that is not sending disconnect. Its your gateway that is playing an announcement during a disconnect event. Your telco is just playing what your gateway is sending.
2. From the logs above your gateway is sending a progress message during a disconnect, hence the suggestion from Manish. This will remove the progress indicator during the disconnect and will just send a disconnect to your provider.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
352
