Community Member
H.323 gateway pri monitoring- snmp
Can we use SNMP to monitor the current number of calls on each PRI line and the total number of calls on all the lines in cisco h.323 gateway.
can snmp monitor the status of each virtual channel in the links individually and not only the link status.
Thanks in advance
jack
1 REPLY
Bronze
Re: H.323 gateway pri monitoring- snmp
The gateway features front and rear panel LED indicators that display status for the unit. You can also access remote diagnostics of the unit through the gateway interface, Telnet, SNMP, or a serial port.
For more info:
http://www.cisco.com/en/US/docs/video/cuvc/release_5_1/gateway/3545/installation/guide/all_gw_functionality.html
214
