H.323 Gateway
What specific models of equipment I can use as H.323 Gateway in the Cisco Call Manager?
  • IP Telephony
Hall of Fame Super Gold
Re: H.323 Gateway
All cisco routers/voice gateway do support h.323.
The CM doesn't care which exact device it is, as long configuration is reasonably correct.
Re: H.323 Gateway
The only requirement for a H.323 is that it support IOS?
Re: H.323 Gateway
Actually I believe that even a non cisco device that complies with H.323 would work as GW with CM.
Re: H.323 Gateway
p.bevilacqua,
I can use a 3545 PRI Gateway ? To route the call of the call manager?
Re: H.323 Gateway
Hi, this is a question you've asked in another thread, someone has provided an answer, honestly I don't know the answer.
Re: H.323 Gateway
i've already replied to your other thread on that and provided a link with the supported gateway models
Have you been able to look at the information?
javalenc
java
if this helps, please rate
www.cisco.com/go/pdi
Re: H.323 Gateway
javalenc, can you provide the links, please!
Re: H.323 Gateway
If you enter your username in the search box on the right side, you will see all the threads you've posted to, and the answers provided.
559
