Showing results forĀ
Search instead forĀ
Did you mean:Ā
h.323 gw& Invalid number format
rmv72
Hello!
i have cisco2911 with 151-4.M3 IOS, gateway configured as h.323 gw on Cisco CUCM.
when i made outside call to PSTN from IP phone i got message
after
TX -> INFORMATION which gw send to PSTN
Aug 14 05:31:25.359: ISDN  Se0/0/0:15 Q931: Sending SETUP  callref = 0x00F4 callID = 0x8077 switch =  primary-net5 interface = User
Aug 14 05:31:25.359: ISDN  Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00F4
        Bearer Capability  i = 0x8090A3
                Standard  = CCITT
                Transfer  Capability = Speech
                Transfer  Mode = Circuit
                Transfer  Rate = 64 kbit/s
        Channel ID i =  0xA9838A
                 Exclusive, Channel 10
        Progress Ind i = 0x8183 - Origination address is  non-ISDN
        Calling Party  Number i = 0x2181, '8xxx420494'
                 Plan:ISDN, Type:National
        Called Party  Number i = 0xA1, '8xxx3815299'
Aug 14 05:31:25.379: ISDN  Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80F4
Aug 14 05:31:25.379: ISDN  Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x80F4
        Progress Ind i = 0x8288 - In-band info or appropriate  now available
Aug 14 05:31:28.959: ISDN  Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref =  0x80F4
Aug 14  05:31:35.359: ISDN Se0/0/0:15 Q931: TX -> INFORMATION pd = 8  callref =  0x00F4
         Sending Complete
Aug 14 05:31:35.371: ISDN  Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80F4
       Cause i = 0x829C  - Invalid number format (incomplete number)
         Display i = 'WRONG NUMBER '
But if i push button "Redial" on IP phone call go with out problem and i don't see message
          Sending Complete
Aug 14 05:32:01.838: ISDN  Se0/0/0:15 Q931: Sending SETUP  callref = 0x00F5 callID = 0x8078 switch =  primary-net5 interface = User
Aug 14 05:32:01.838: ISDN  Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00F5
                Standard  = CCITT
Aug 14 05:32:01.854: ISDN  Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80F5
Aug 14 05:32:01.858: ISDN  Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x80F5
Aug 14 05:32:05.106: ISDN  Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref =  0x80F5
Aug 14 05:32:17.714: ISDN  Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80F5
        Cause i = 0x8391  - User busy
        Display i = 'BUSY
How to get rid of INFORMATION message?
Best regards,
Mike
Chris Deren
Is the 8 part of the number or the prefix? Post your dial peer configuration.
Chris
