H.323 GW - SIP Calls cannot go through
I have a CUCM 7.1.5 working properly, with a H.323 gateway. External calls needs to go through via SIP Provider.
I have installed a CUBE IOS on the H.323 gateway and SIP Calls to SIP provider cannot go through.
ON CUCM side, MTP, Inbound and Outbound fast start are enabled. SIP Calls are going through using G.729r8 codec.
I'm not to identify why the call cannot go through, seems that everything is configured properly, but cannot identify what's wrong.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
  emptycapability
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  registrar server expires max 3600 min 3600
  redirect contact order best-match
  localhost dns:sip.solutionsvoip.com.br
voice class codec 1
codec preference 1 g729r8
codec preference 3 g711alaw
codec preference 4 g711ulaw
voice class h323 1
  h225 timeout tcp establish 2
  call start fast
  no call preserve
ip address 192.168.1.5 255.255.255.0
speed 100
full-duplex
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.1.5
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 2 register SP_TRANSCODER01
associate profile 1 register SP_MTP01
dspfarm profile 2 transcode universal
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
maximum sessions 1
associate application SCCP
dspfarm profile 1 mtp
codec g729r8
maximum sessions software 100
dial-peer voice 3 voip
description Local Calls
translation-profile outgoing DIGITSTRIP-CUCM
destination-pattern 11[2-9].......
session protocol sipv2
session target sip-server
session transport udp
voice-class codec 1
voice-class h323 1
dtmf-relay rtp-nte
no vad
dial-peer voice 5 voip
incoming called-number .T
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
sip-ua
credentials username 116618 password 7 12345 realm sip.solutionsvoip.com.br
authentication username 116618 password 7 12345 realm sip.solutionsvoip.com.br
retry invite 4
retry response 3
retry bye 3
retry cancel 2
retry register 10
timers register 100
registrar dns:sip.solutionsvoip.com.br expires 3600
sip-server dns:sip.solutionsvoip.com.br
host-registrar
I have attached the full sh run
What's wrong for this environment?
Thank you and I really appreciate any help
16 Replies 16
Chris Deren
What IOS version did you install?
If 15.1T + add the following command:
voice service voip
no ip address trusted authenticate
If that does not help, post "debug ccsip messages" for failed call.
HTH,
Chris
No, the IOS is 15.0.1
Can you post the debug then?
Chris
Please take a look on the traces
heathrw
Level 4
Level 4
Is that making calls or receiving calls?
Ask your service provider if they have configuration guidelines for CUBE
as they might have specific requirements and save some time.
I'm making calls...
You are not getting back anything from provider after your INVITE message, is your authentication working?  Can you ping their Proxy?  I suggest you contact your provider for assistance.
HTH,
Chris
Yes, the authentication seems to be working fine, because the router is registered normally when I type the command show sip-ua register status
This is the second SIP Provider and I cannot estabilish the connection
Can you recieve calls?
I'm not trying to receive calls, because I only have plan to place external calls.
Anything else?
In your logs-new.zip, I am only seeing outbound SIP messages sent to your provider. Where is the rest, or are you not receiving anything?
Please remember to rate useful posts, by clicking on the stars below.
khayes1984
So you do not have inbound VoIP dial-peers coming to CM. You need the following
dialpeer voice 2 voip
description Incoming to Cisco Unified CM Sub or Pub (Which ever)
destination target " DID"
session target ipv4: ip of CM
.dtmf-relay rtp-nte or dtmf-relay h245-alphanumeric, or dtmf-relay sip-notify force rtp-nte <-- not sure on this one but check to make sure I'm correct
no vad
description Incoming to Cisco CM Cluster
destination target .
dtmf-relay rtp-nte or dtmf-relay h245-alphanumeric, or dtmf-relay sip-notify force rtp-nte <-- not sure on this one but check to make sure I'm correct again.
no vad
check this commands to make sure they are laid out right, I'm half asleep so lol, also make sure you have voice translation rules to translate your inbound and outbound calls.
I'm not getting SIP INVITE reply.
I have checked and I'm getting SIIP INVITE timeout.
How I can fix that?
Anyone else?
