H.323 Incoming calling issue
hi all,
i got registered H.323 GW with CCM 6.1 ... my outgoing calls are working fine but for incoming i cant ... result of debug isdn q931 is follow
TRA-GW#
*Mar 19 17:35:12.783: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x172D
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18385
Preferred, Channel 5
Calling Party Number i = 0x2183, '39967808'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '17520007'
Plan:ISDN, Type:Subscriber(local)
*Mar 19 17:35:12.795: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x972D
Channel ID i = 0xA98385
Exclusive, Channel 5
*Mar 19 17:35:12.803: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x972D
Cause i = 0x8081 - Unallocated/unassigned number
*Mar 19 17:35:12.887: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x172D
*Mar 19 17:35:12.891: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x972D
*Mar 19 17:36:45.691: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x1740
Sending Complete
Standard = CCITT
Channel ID i = 0xA18386
Preferred, Channel 6
*Mar 19 17:36:45.703: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x9740
Channel ID i = 0xA98386
Exclusive, Channel 6
*Mar 19 17:36:45.711: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x9740
*Mar 19 17:36:45.787: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x1740
*Mar 19 17:36:45.791: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9740
TRA-GW#
my phones extension is 007, i tried to configure incoming from translation pattern but it didnt work ,then i tried to configure translation rule for incoming .. my config is as following
TRA-GW#
TRA-GW#sh run
Building configuration...
Current configuration : 7402 bytes
card type e1 0 0
ip domain name yourdomain.com
isdn switch-type primary-4ess
voice-card 0
no dspfarm
voice translation-rule 1
rule 1 /^17520/ //
voice translation-rule 300
rule 1 // //
voice translation-profile PSTNIN
translate called 1
voice translation-profile PSTNOUT
translate calling 300
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
interface FastEthernet0/1
ip address 192.168.193.3 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
interface Serial0/0/0:15
no ip address
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
voice-port 0/0/0:15
translation-profile incoming PSTNIN
translation-profile outgoing PSTNOUT
dial-peer voice 1 pots
destination-pattern 917......
no digit-strip
direct-inward-dial
port 0/0/0:15
forward-digits 8
end
TRA-GW#
as you can see called number 17520007,i tried to configure this complete number as extension of phone but still same error..Can any one help me out URGENT for my mistake or solution plzz
Re: H.323 Incoming calling issue
I don't see a dial peer here.
dial-peer voice 2 voip
codec g711ulaw (or g729r8)
destination-pattern .T
session target ipv4:
dtmf-relay h245-alpha
incoming called-number .
On your H323 gateway you can set 'significant digits' to 3, or set a translation pattern if you don't want all calls to be 3 digits.
hth,
nick
hi nick,
thanks for your reply .. is that the only issue which you diagnosed via debugs ???? or is there any other possibilities could be there !!!
one more question nick, tell me difference between translate called or translate calling number ... i have confusion about both of them ...also what if i will use translate calling in translation-profile PSTNIN instead of translate called like in below example
translate called 1
or is it necessary to configure translate called with PSTNIN profile ... if you can then plz tell the difference or affects for called or calling translation rules in translation profile or can you plz refer any guide
regards
161
