H.323 or SIP?
Is it possible to know whether a call is signalled using H.323 or SIP?
Right now I just can see SIP calls using command: show sip-ua calls.
Thanks in advance.
Jaime Valencia
you can try with sh call active voice
java
if this helps, please rate
java
Thanks, but is there a fastest way to see H.323 calls only? Maybe an equivalent to SH SIP-UA CALLS...
Thanks.
You can use
"sh call active voice brief"
you'll get something like at the end of the output:
Telephony call-legs: 1
SIP call-legs: 2
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Media call-legs: 0
Total call-legs: 3
HTH,
Chris
OK, thanks. It helped me a lot.
One more question: is there a way to know whether an active call is a H323 or SIP call?
