H.323 Trunk selection order - failed trunk
When using MGCP with CUCM if there is a failed trunk, it realizes it's failed and jumps to the next trunk.
When using H.323 (my personal preference) if the trunk it choses does not work, it simply fails dropping fast busy to the end user - making the rest of the lines useless. Is there a command in the IOS to tell it to try the next trunk in a trunk list in the event of failure?
1 ACCEPTED SOLUTION
Re: H.323 Trunk selection order - failed trunk
change this on CUCM
Clusterwide Parameters (Route Plan)
Stop Routing on Unallocated Number Flag = False
Stop Routing on User Busy Flag = Flag
or on GW:
no dial-peer outbound status-check pots
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
change this on CUCM
or on GW:
java
java
171
