H.3232 gateway with E1 & FXO interfaces
I have CUCM 9.1 with a gateway having E1 interface & 4 FXO interfaces.
Can any body tell how to configure H.323 gateway having FXO interfaces ?
E1 interface is working fine, i have doubt about FXO configuration, how it will be configured into CUCM 9.0 ? I have SIP 9900 series phones.
  • IP Telephony
1 REPLY
Hall of Fame Super Silver
All you need to do for the
All you need to do for the FXO line is build proper POTS dial peers pointing to it.  On CUCM you don't have to do anything as you already have the GW configured for the E1 so it is shared, you separate the traffic via dial-peers on the GW. For inbound calls add "plar" configuration to the port to define where you want the calls to go.
Chris
89
