h245 tunnel disable, how?
Hello:
I have a ios (C2801-IPVOICE_IVS-M), Version 12.4(20)T1, RELEASE SOFTWARE (fc3)
And I want to disable the h245 tunnel.
This feature is disabled when the h245 tunnel disable command is issued.
I don't have this command.
anyone can say me why?
Antonio
1 ACCEPTED SOLUTION
Re: h245 tunnel disable, how?
This command is hidden so you won't see. Just type it
voice service voip
h323
h245 tunnel disable
BR,
Stoyan
voice service voip
h323
h245 tunnel disable
BR,
Stoyan
Hello:
You are right. Thanks. Can you say me why there are commander that are hidden?
815
