05-14-2008 12:21 PM - edited 03-15-2019 10:40 AM
we are note getting a stable connection at call initialization. We hear one ring on our end, then the call dies. about 30-40 secs later it rings again and we can answer the call. all of the callers say there is dead silence when they dial, they think the call didn't go through, so then hang up and try a second time.
This site has only FXO ports and is running H.323
any ideas ?
thank you
05-14-2008 12:26 PM
Check h323 bind command in GW,
In CCM check proper IP address...
Any firewall in between ?
Make sure dial-peers and plar commands are configured properly, can you attach your config and debug voice ccapi ino and debug vpm signal
05-14-2008 12:46 PM
I thought about the bind command too.
I'm not sure if we have a firewall, I will have to confirm that
I'm attaching the config with the debug output
05-14-2008 04:19 PM
Hola Cris,
The outgoing dial-peer is 2
the incoming one is the 900
In CCM for that GW and IP Phone which region is configured? GW should be announcing both
G711 or G729
Cal disconnection is 16 normal call clearing
Can you disable G722 codec and send me also CCM detailed trace?
05-19-2008 09:35 AM
Hola Goga,
I was checking the GW config and the codec G722 is not configured. or where do you want me to go to disable ghe G722 codec ?
05-19-2008 10:03 AM
most probably goga refers to the enterprise parameter:
Advertise G.722 Codec
javalenc
if this helps, please rate
