Community Member
H323 call preserve on WAN failure
I added call preserve under voice service voip, and set the clusterwide parameter to true, made a call and failed the WAN, the call held up no problem, I could see the preserved call under 'show h323 calls preserved', all good.
Problem is when the call is ended and I do 'show ISDN active', the call is still held up, any ideas?
Tim
Re: H323 call preserve on WAN failure
Tim,
You'll need to configure/enable the media inactivity timer feature so that the call is torn down when both parties hang up. It's covered in the following documentation.
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_h323_configuration_guide/old_archives_h323/4gwconf.html#wp1149764
-Felipe
Community Member
Hi Felipe
Done that, works a treat, thanks V much........
271
