04-22-2012 06:44 AM - edited 03-16-2019 10:45 AM
Gents,
I have CUCM 6.1.2 with H323 GWs. After I upgraded the Firmware on ip phones, sometimes the land lines calls terminated to internal extensions.
note: IP phones became very fast in initiating the call setup after the upgrading.
i think it is a matter of H323 timers, as i think i have to increase the H323 timers to wait for call setup with the GW.
Am i correct? if yes, what is the timer?
BR,
ahmed kamal
04-22-2012 07:14 AM
Example of call setup:
27974477 instead of going to land line it collects "4477" and calls the internal "4477" extension.
04-22-2012 04:32 PM
That has nothing to do with H323 or any other protocol since the call at least from what you're explaining is not even reaching the GW, check your dial plan to see what you're really hitting when you dial that.
Most likely you're hitting a TP that strips the digits.
If it's hitting the GW, still, you're hitting something that you have configured that's redirecting the call back to CUCM.
Nothing to do with timers.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
04-23-2012 01:14 AM
i am hitting the GW, i could see that from the debug isdn q931.
04-23-2012 01:21 AM
call sometimes goes well in non peak hours and some times goes to internal extensions
04-29-2012 02:47 AM
The problem was in the IOS on my GW. I did the IOS upgrade and it fixed.
