H323 Cannot make outbound calls, OK Inbound
I cannot make outbound calls, but inbound call is ok. We are installing 2 new T1's and have the first 5 channels up for testing, we have a test number 2580 coming in but when I make a call from the inside I get an error. Here's the dubug and the config:
*Nov 28 06:58:50.090: ISDN Se1/0:23 Q931: pak_private_number: Invalid type/plan
0x0 0x0 may be overriden; sw-type 2
*Nov 28 06:58:50.090: ISDN Se1/0:23 Q931: Applying typeplan for sw-type 0x2 is 0
x2 0x1, Calling num 8702
*Nov 28 06:58:50.094: ISDN Se1/0:23 Q931: Applying typeplan for sw-type 0x2 is 0
x0 0x0, Called num 16307909496
*Nov 28 06:58:50.098: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0085
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE9808385
Exclusive, Interface 0, Channel 5
Net Specific Fac i = 0x00E3
Calling Party Number i = 0x2181, '8702'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '16307909496'
Plan:Unknown, Type:Unknown
*Nov 28 06:58:50.166: ISDN Se1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x80
85
*Nov 28 06:58:50.182: ISDN Se1/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x808
Cause i = 0x8381 - Unallocated/unassigned number
Progress Ind i = 0x8381 - Call not end-to-end ISDN, may have in-band inf
o
*Nov 28 06:59:09.030: ISDN Se1/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x8
085
Cause i = 0x8390 - Normal call clearing
*Nov 28 06:59:09.038: ISDN Se1/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x0085
*Nov 28 06:59:09.090: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0
x8085
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
isdn switch-type primary-4ess
voice-card 1
password encryption aes
voice call send-alert
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24 nfas_d primary nfas_int 0 nfas_group 1
controller T1 1/1
framing esf
linecode b8zs
pri-group timeslots 1-24 nfas_d backup nfas_int 1 nfas_group 1
interface FastEthernet0/0
description Connection_to_Data_Vlan
ip address 10.XX.0.XXX 255.255.0.0
speed 100
full-duplex
standby 1 preempt
interface FastEthernet0/1
ip address 10.129.0.104 255.255.0.0
speed 100
full-duplex
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.129.0.104
interface Serial1/0:23
ip address 10.1.1.1 255.255.255.0
no logging event link-status
dialer map ip 10.1.1.2 name megamap class megaplan megaplan
isdn incoming-voice voice
isdn T306 60000
isdn nsf-service megacom
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.129.0.1
ip http server
map-class dialer megaplan
dialer voice-call
dialer outgoing mega
control-plane
voice-port 1/0:23
voice-port 1/1:23
dial-peer voice 100 voip
tone ringback alert-no-PI
preference 1
destination-pattern 2580
session target ipv4:10.129.1.1
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw bytes 80
no vad
dial-peer voice 1 pots
description PSTNpots
destination-pattern .T
direct-inward-dial
port 1/0:23
forward-digits all
gateway
emulate cisco h323 bandwidth
Green
Re: H323 Cannot make outbound calls, OK Inbound
Telco is disconnecting the call, I see that you are using NSF, could you please confirm with them that correct NSF is sent and switch is correct (isdn switch-type primary-4ess ) or what they are expecting from us in order to no disconnect the call?
BTW why you have dialer map ip configured under the serial?
I have verified that they are using NSF, when I remove it I get the following error:
*Nov 28 08:45:42.290: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0
x80B1
Cause i = 0x83E020 - Mandatory information element missing
I removed the dialer map, I don't know why the customer had it in there.
Hall of Fame Super Gold
more likely the problem is in the number format, have you tried local calls with seven digits? You are sending out a four digit extension, is that what they want? Also ask what type/plan they want in the setup message.
563
