H323 Cause Value=41
Hi All,
Kindly note that we have the below topology:
PSTN---->H323 VGW-1(E1)----->CUCM 8.5------>UCCX 8.5------>Agent (CAD & CIPC)
but we have a problem that some calls answered by the the agent but after some time it disconnected with Disconnect Cause=41 & Disconnect Cause=31.
and the configuration on VGW-1 like below:
hostname VOICE-GATEWAY-1
boot-start-marker
boot-end-marker
card type e1 0 0
no aaa new-model
clock timezone Amman 2 0
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
isdn switch-type primary-4ess
voice-card 0
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 2
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class h323 10
  h225 timeout tcp establish 3
voice translation-rule 1
rule 1 /5679141/ /*150/
rule 2 /5100731/ /7311/
rule 3 /5100732/ /7024/
voice translation-rule 2
rule 1 /7.../ /5679141/
rule 2 /7311/ /5100731/
voice translation-rule 3
rule 1 /\(.*\)/ /9\1/
voice translation-profile INC
translate calling 3
translate called 1
voice translation-profile OUT
translate calling 2
voice translation-profile Prefix_9
translate calling 3
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
controller E1 0/0/0
pri-group timeslots 1-31
bridge irb
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.19
encapsulation dot1Q 19
bridge-group 19
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
bridge-group 20
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.19
bridge-group 19
interface GigabitEthernet0/1.20
bridge-group 20
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
interface BVI19
ip address 192.168.19.1 255.255.255.0
interface BVI20
ip address 192.168.20.1 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.20.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.20.3
control-plane
bridge 19 protocol ieee
bridge 19 route ip
bridge 20 protocol ieee
bridge 20 route ip
voice-port 0/0/0:15
voice-port 0/1/0
echo-cancel coverage 64
shutdown
voice-port 0/1/1
no ccm-manager fax protocol cisco
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp profile default
dial-peer voice 2 pots
translation-profile incoming INC
incoming called-number .
direct-inward-dial
dial-peer voice 150 voip
preference 2
destination-pattern *150
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
session target ipv4:192.168.20.10
voice-class codec 2
voice-class h323 10
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 151 voip
preference 1
session target ipv4:192.168.20.11
voice-class codec 2
voice-class h323 10
no vad
dial-peer voice 1 voip
codec g711alaw
no vad
dial-peer voice 9 pots
destination-pattern 9T
port 0/0/0:15
dial-peer voice 7000 voip
preference 1
destination-pattern 7...
codec g711alaw
no vad
gateway
media-inactivity-criteria rtp
timer media-inactive 10
timer receive-rtp 1200
gatekeeper
shutdown
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
ntp master 9
ntp update-calendar
ntp server ip 192.168.20.3
end
VOICE-GATEWAY-1#sh version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1).
Everyone's tags (2)
H323 Cause Value=41
Temporary failure
Typical scenarios include:
Network failure.
41
Indicates that the network is not functioning correctly and that the condition is likely to be resolved quickly.
Voice CCIE #37771
H323 Cause Value=41
So the Problem is in the network, and there is no prolem in the configuration.
and if the problem in the network, why the problem happened in some calls, and how to know where is the problem, and kindly note that there in no firewall between the CUCM, VGW, and Agents.
H323 Cause Value=41
it seems so yes, any the problem with network errors is it is also intermittend, maybe the qos is not working 100% and when the load on the network gets to high.
If the FW had an issue all calls would have been dropped unless there is some sort of bw setting for qos on the FW
Voice CCIE #37771
H323 Cause Value=41
This is our network topology, and we are not configured the QoS because all calls on the lan, and the calls dropped in time that there few number of calls.
H323 Cause Value=41
any spanning tree setup on the network?
Voice CCIE #37771
Re: H323 Cause Value=41
yes, and we configure the core-1 as the root bridge, and you can see the sh spanning-tree & sh runn in the attachment, but there is a strange issue on the switches, the issue is the switches see non physical neighbor in the show cdp neighbor you can see that on Agents_sw_1.txt, and i am sure that there no hub between them, and thank you.
H323 Cause Value=41
The problem was on the Agent PC that was block the traffic from the VGW to the CIPC.
H323 Cause Value=41
in sort then it was a network issue, the PC was blocking the network....
Voice CCIE #37771
1330
