05-26-2009 07:38 AM - edited 03-15-2019 06:12 PM
How do you specify channel selection order on a PRI with h323? I remember something like channel selection sequential, but cant remember where it is applied. thanks
Solved! Go to Solution.
05-26-2009 07:45 AM
You normally leave the default, if you can prove that it is not ok, then use isdn bchan-number-order under interface.
05-26-2009 07:45 AM
05-26-2009 07:52 AM
Thanks for the info
