09-23-2013 02:14 PM - edited 03-16-2019 07:30 PM
Hi All
I have an issue with calls hitting my CUCM 7.0 from a Cisco 3825 Voice Gateway.
I have a PBX connected via E1 to the 3825 VG and at present I can call from the CallManager to the PBX through the 3825 Voice Gateway with no problems. However I am unable to call from the PBX to the CallManager through the 3825 Voice Gateway.
I've been using CallManager version 8.0 in my lab for some other testing and have been using the "Calllogs" via "View Real Time Data" within the RTMT. Now when I try to find the same tool in CallManager v 7.0 (my live network) I dont have the same options so cant find the sme tool??
When I use CallManager v8.0 I can find the Calllogs too via the following: Trace & Log Central / Real Time Trace / View Real Time Data
Products: - UCM
Services: - Cisco CallManager
Trace File Type: - calllogs
However, In version 7.0 I don't seem to have this option! Is this option avalabe in version 7.0 and if so where?
Here is a screen cap of calllogs I have been using in version 8.0
Here is some infomation on my setup and the errors I have been getting:
Calls from the CUCM to PBX via 3825 VG set as H323 Gateway: WORKING
Calls from the PBX to CUCM via 3825 VG set as H323 Gateway: NOT WORKING
A test call from 1022044 on the PBX to 77301 a DN on the CallManager with "DEBUG ISDN Q931" set on the Voice Gateway shows:
Cause i = 0x8081 - Unallocated/unassigned number
My Voice Gateway setup is as follows:
~~~~Sensative infomation removed~~~~
isdn switch-type primary-qsig
voice-card 0
no dspfarm
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice translation-rule 1
rule 1 /.*\(7....\)$/ /\1/
voice translation-profile InboundE1
translate called 1
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-31
description QSIG connection to PBX 1
controller E1 0/1/1
framing NO-CRC4
description QSIG connection to PBX 2
ip ssh version 1
interface Loopback0
ip address X.X.X.X 255.255.255.255
h323-gateway voip bind srcaddr X.X.X.X
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/1/1:15
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/1/0:15
timeouts interdigit 2
description QSIG Port 1 to PBX1
voice-port 0/1/1:15
translation-profile incoming InboundE1
description QSIG Port 2 to PBX2
dial-peer voice 700 voip
preference 5
destination-pattern 7....
progress_ind setup enable 3
modem passthrough nse codec g711ulaw
voice-class codec 1
session target ipv4:<CUCM1>
dtmf-relay h245-alphanumeric
fax rate disable
no vad
dial-peer voice 701 voip
preference 10
voice-class codec 1
session target ipv4:<CUCM2>
fax rate disable
no vad
dial-peer voice 999001 pots
description Calls to Tetra
destination-pattern 9102....
incoming called-number .
direct-inward-dial
port 0/1/0:15
forward-digits 7
dial-peer voice 99900 pots
description TETRA Group calls
destination-pattern 103....
direct-inward-dial
port 0/1/1:15
forward-digits all
dial-peer voice 999002 pots
destination-pattern 102....
direct-inward-dial
port 0/1/0:15
forward-digits all
gateway
timer receive-rtp 1200
call-manager-fallback
max-conferences 12 gain -6
transfer-system full-consult
ip source-address X.X.X.X port 2000
max-ephones 200
max-dn 200
end
Solved! Go to Solution.
09-23-2013 02:36 PM
Hello
Can you please please check the below points:-
1- Add the below config to your GW
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 3
voice class h323 1
voice class h323 1
On CUCM device -gateway
2-on CUCM :Check that your GW have the CSS which can be reacheble by your phones.
3-on CUCM :gateway make significant digits "5" , as the below
Thank you
please rate all useful information
09-23-2013 02:36 PM
Hello
voice class h323 1
voice class h323 1
voice class h323 1
Thank you
09-23-2013 04:34 PM
Lee,
Un allocated/un assigned number is certainly a CSS issue. Check the CSS on your gateway under inbound calls. Ensure that CSS has access to the partition of the phones
09-23-2013 07:36 PM
I would have also tested the translation rule and debug dialpeer .
Please remember to rate useful posts, by clicking on the stars below.
09-23-2013 10:06 PM
Hi Lee,
You need to check few things for this:-
1). Collect "debug isdn q931" and share it.
2). Check whether call setup message is being sent to CUCM or not? (you can use debug voip dialpeer)
3). Check the dialed number is in any partition? If yes, then check appropriate CSS is applied at gateway level.
Nishant Savalia
09-23-2013 10:37 PM
Hi Guy's
Many thanks for the helpful infomation, I have access to the system latter today and we post back in this thread latter!
I suspect it is a CSS Issue but will also add the config to the gateway, there has been some changes to the design so the GW needs to be cleaned up and some ISDN config removed.
One thing I would still like to find is the RTMT CallLogs! As mentioned before when I use CallManager v8.0 I can find the Calllogs via the following: Trace & Log Central / Real Time Trace / View Real Time Data
In CUCM v 7.0 I dont have this option or I cant find it?
Many thanks
Lee
09-24-2013 01:20 AM
Lee,
That field is not available in CUCM7. I am not sure why you want it though. What you need is SDI trace log files. This is where you start your troubleshooting..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
09-24-2013 11:08 AM
Hi Guy's
Many thanks for all the help with this, I'm working on a clossed network so hard to accress the internet so sorry for late reply!
I was able to get this working in about 30min's this morning, I changed the "CSS" on the "Inbound Routing Infomation - Inbound Calls".
Again, many thanks!
Lee
