H323 Dial Peer matching based on ANI.
I have a site with 4 diferent companies who use the same gateway to receive calls. I recently switched them from MGCP to H323. While previously with MGCP it was easy to route calls from each company to a particular BRI through route groups and lists, I am now trying to accomplish something similar with dial peers but drawing a blank as to how this can be accomplished if at all. Now the are routed to an offsite PRI for outbound calls managed through MGCP but I would like to know if this is possible through dial peer matching and H323.
What I want to do is based on the calling number, for example 1000 (an extension) match an outbound dial peer with voice port for example 0/1/0 (the voice port used for incoming calls to this extension should also be used for outbout calls only for range 1000-1020 for example.) For extensions 1100-1120 only use voice port 0/1/1.
dial-peer voice 21 pots
description company X
answer-address 10[0-2]0
destination-pattern [89][1-9].......
  direct-inward-dial
port 0/1/1
dial-peer voice 14 pots
  description company Y
  answer-address 11[0-2]0
  direct-inward-dial
port 0/1/0
Is the pots dial peer here based on preference or is it matched based on the calling number ex. 1100.
Thanks in advance.
Ron
1 REPLY
Hall of Fame Super Gold
Re: H323 Dial Peer matching based on ANI.
This is asked often. See:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
It is also possible to achieve the same by using COR instead that number manipulation. In either case, the key concept is matching ANI via "answer-address" on incoming voip DP.
289
