I have some Pots dial peers that I need to perform the following tasks to:
Strip the first 2 digits
Use the last 4 digits and then prefix a number to it. I've looked at the digit strip command which is on by default and I just need to get this checked before I go live.
dial-peer voice 11 pots
destination-pattern 29....
progress_ind setup enable 3
progress_ind alert enable 8
prefix 01222453...
direct-inward-dial
port 0/0/0:15
The final number I need is 01222453666 from someone dialling 291666.
Cheers
D
