Community Member
h323 dial peers for 7 digit dialing
I need to configure an H323 gateway to support 10 digit and 7 digit local dialing in my pots dial peers.   What is the correct way to do this without hitting the interdigit timeout on the 7 digit pattern?   Here are my dial peers:
dial-peer voice 4 pots
description 10-Digit Local Calls
preference 1
destination-pattern 9301[2-9]......
port 0/0/0:23
forward-digits 10
dial-peer voice 7 pots
description 7-Digit Local Calls
preference 1
destination-pattern 9[2-9]......
direct-inward-dial
forward-digits 7
Thanks in advance,
Glenn
1 REPLY
Community Member
Never mind on this.   I answered my own question.   As long as I'm not dialing a 301 area code, I should only be matching the 7 digit peer.
Glenn
263
