Community Member
H323 difference between tone ringback alert-no-pi and progress_ind setup?
What is the difference between tone ringback alert-no-pi and progress_ind setup?
1 REPLY
Community Member
Re: H323 difference between tone ringback alert-no-pi and progre
progress_ind
To set a specific progress indicator (PI) in call setup, progress, or connect messages from an H.323 VoIP gateway, use the progress_ind command in dial-peer configuration mode.
tone ringback alert-no-PI
To generate automatic ringback for the caller when no Progress Indicator (PI) alert has been received over the H.323 network, use the tone ringback alert-no-PI command in dial-peer configuration mode.
623
