H323 dissconnection problem..
  Hi All,
I have a CUCM 8.0 in the HO. I have setup a new branch connected by DSL to HO. I have configured an H323 voice gateway in the branch I am getting a dificulty to establish off-net call over the PSTN, when I type the debuge voip ccapi inout, i am getting the following:
voip ccapi inout debugging is on
Makkah-2901R#
Jun 30 11:28:29.587: //-1/009083372400/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Loay Al-Qattaa
   ----- ccCallInfo IE subfields -----
   cisco-ani=252
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=96532116
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jun 30 11:28:29.587: //-1/009083372400/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x30AAA85C, Call Info(
   Calling Number=252,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User,
Passed, Presentation=Allowed),
   Called Number=96532116(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=T
RUE,
   Incoming Dial-peer=2, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS
E), Call Id=30
Jun 30 11:28:29.587: //-1/009083372400/CCAPI/ccCheckClipClir:
   In: Calling Number=252(TON=Unknown, NPI=Unknown, Screening=User, Passed, Pres
entation=Allowed)
   Out: Calling Number=252(TON=Unknown, NPI=Unknown, Screening=User, Passed, Pre
sentation=Allowed)
Jun 30 11:28:29.587: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 30 11:28:29.587: :cc_get_feature_vsa malloc success
Jun 30 11:28:29.587:  cc_get_feature_vsa count is 1
Jun 30 11:28:29.587: :FEATURE_VSA attributes are: feature_name:0,feature_time:73
9446392,feature_id:30
Jun 30 11:28:29.591: //30/009083372400/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=252(TON=Unknown, NPI=Unknown, Screening=User, Passed
   Called Number=96532116(TON=Unknown, NPI=Unknown))
Jun 30 11:28:29.591: //30/009083372400/CCAPI/cc_process_call_setup_ind:
   Event=0x311E5238
Jun 30 11:28:29.591: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 96532116
Jun 30 11:28:29.591: //30/009083372400/CCAPI/ccCallSetContext:
   Context=0x2ABCF718
   >>>>CCAPI handed cid 30 with tag 2 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Jun 30 11:28:29.591: //30/009083372400/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C
ause=0)
   Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
Jun 30 11:28:29.591: //30/009083372400/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jun 30 11:28:29.591: //30/009083372400/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30AAA85C, Tag=0x0, Call Id=30,
   Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jun 30 11:28:29.591: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun 30 11:28:29.591: :cc_free_feature_vsa freeing 2C130E70
Jun 30 11:28:29.591:  vsacount in free is 0
the voice gateway in branch is 2901 and configured as h323 gateway:
dial-peer voice 1 pots
destination-pattern 9T
port 0/0/0
dial-peer voice 2 voip
description Incoming From CUCM
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711alaw
port 0/0/0
codec g711alaw
Please advice, why i am getting the dissconnect and unable to estaplisg off-net call?
Everyone's tags (1)
VIP Super Bronze
You need to configure the ff: on your branch gateway
voice service voip
ip address trusted list
ipv4 x.x.x.x 255.255.255.255....................x.x.x.x= ip address of your cucm server(s)
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi aokanlawon,
Thanks a lot. it is working fine now.
VIP Super Bronze
I am glad it worked. Please rate useful posts! It helps every one on the forum to know the right answers and encourages us too
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
326
