Community Member
H323 Fast Start Issue
Hi all,
Call start Fast was dropping calls with Temporary Failure (41) after put on hold and in show call history voice id, RemoteUDPPort=0.
If I change to call start slow, calls are OK, but I need use fast start.
Scenario is:
PSTN -> GW (E1 CAS) -> Device SCCP (CUCM 7.x)
GW config
voice class h323 1
  h225 timeout tcp establish 3
  call start fast
  call preserve
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
dial-peer voice 110 voip
destination pattern 74.........$
rtp payload-type comfort-noise 13
voice class h323 1
voice class codec 1
session target ipv4:10.0.0.10
dtmf-relay h245-alphanumeric
fax-relay ecm disable
ip qos dscp cs3 signaling
no vad
The Enable Inbound FastStart was checked in CUCM GW config.
Any idea???
Lonardoni
Everyone's tags (3)
1 REPLY
Do you have already seen these notes?
https://supportforums.cisco.com/thread/2112035
What's happen if you try to disable h245 tunnel?
Regrds.
1251
