08-04-2007 06:40 AM - edited 03-14-2019 10:56 PM
CCM5.1.2, IOS12.4.11.T3, VIC2-4FXO
when I dial out via FXO, CCM sending to gateway the calling number '4501119991' successfully but lost in gateway and cannot send out to PSTN.
Advise please,
configuration
voice-port 0/0/0
connection plar opx 5100
caller-id enable
dial-peer
dial-peer voice 220 pots
destination-pattern 9[2-9]..[2-9]......
port 0/0/0
forward-digits 10
debug voice dialpeer
*Aug 4 14:39:14.722: //-1/00BB48670C00/DPM/dpAssociateIncomingPeerCore:
Calling Number=4501119991, Called Number=94502223333, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=101
*Aug 4 14:39:14.730: //-1/00BB48670C00/DPM/dpMatchPeersCore:
Calling Number=, Called Number=94502223333, Peer Info Type=DIALPEER_INFO_SPEE
CH
Match Rule=DP_MATCH_DEST; Called Number=94502223333
*Aug 4 14:39:14.734: //-1/00BB48670C00/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
*Aug 4 14:39:14.734: //-1/00BB48670C00/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=220
Solved! Go to Solution.
08-04-2007 06:59 AM
Yes, you cannot send calling number on analog lines. If you want to do that, get ISDN.
08-04-2007 06:55 AM
it may stupid question since the analog calling number (outbound) is controlling by carrier. cannot send out my calling number. Am I correct?
08-04-2007 06:59 AM
