11-13-2008 12:05 PM - edited 03-15-2019 02:32 PM
I am running CCM 4.1
We have a remote office with 4 analog lines connect to the routers FXO ports.
THis site uses these 4 lines for local calling only.
We have this gateway setup as a H323 gateway in call manager
problem - When all 4 lines fill up the next call will get a busy signal. If they put the area code in it works because it will get routed out the corp office.
I creted a remote route list with two groups. group 1 = local 4 pots
group 2 = corp long distance.
Now I setup this list for primary is group 1 and then if it goes to group two it will append the area code and use the corp one. This is not happening (the using of the second group)
I think its because this is a H323 gateway and call manager isnt controling it.
Would I correct this with dial peers.
I currently have [2-9]...... setup 4 times with presidence 1-4. <-- these are POTS dial-peers
Would I create a voip dial-peer with [2-9]...... and set it with a presedence of 5 ?
11-13-2008 01:48 PM
Try changin CM service parameter "stop routing on user busy flag" to FALSE and see if that helps you.
Chris
11-14-2008 05:26 AM
not hat didnt work. I got it working by doing the following
dial-peer 100 voice pots
dest-pat [2-9]......
port 0/1/0
prefer 0
dial-peer 150 voice pots
port 0/1/1
prefer 1
dial-peer 200 voice voip
target session - call manager
prefer 2
then on call manager i added a route pattern for that gateway's css [2-9]XXXXXX and i sent it out the corp pri with the proper area codes appended.
