Community Member
H323 gateway and dial peers
I am running CCM 4.1
We have a remote office with 4 analog lines connect to the routers FXO ports.
THis site uses these 4 lines for local calling only.
We have this gateway setup as a H323 gateway in call manager
problem - When all 4 lines fill up the next call will get a busy signal. If they put the area code in it works because it will get routed out the corp office.
I creted a remote route list with two groups. group 1 = local 4 pots
group 2 = corp long distance.
Now I setup this list for primary is group 1 and then if it goes to group two it will append the area code and use the corp one. This is not happening (the using of the second group)
I think its because this is a H323 gateway and call manager isnt controling it.
Would I correct this with dial peers.
I currently have [2-9]...... setup 4 times with presidence 1-4. <-- these are POTS dial-peers
Would I create a voip dial-peer with [2-9]...... and set it with a presedence of 5 ?
Hall of Fame Super Silver
Re: H323 gateway and dial peers
Try changin CM service parameter "stop routing on user busy flag" to FALSE and see if that helps you.
Chris
Community Member
not hat didnt work. I got it working by doing the following
dial-peer 100 voice pots
dest-pat [2-9]......
port 0/1/0
prefer 0
dial-peer 150 voice pots
port 0/1/1
prefer 1
dial-peer 200 voice voip
target session - call manager
prefer 2
then on call manager i added a route pattern for that gateway's css [2-9]XXXXXX and i sent it out the corp pri with the proper area codes appended.
298
