H323 Gateway Call Preservation Failure
Have CallManagers at central site and an H323 gateway with PRI at remote site. All devices are registered to the Subscriber with Publisher as secondary.
When remote site is on an active PRI and the SUB goes down, the call is preserved. However, if the SUB comes back online during the same call, the call terminates right at 10 seconds every time. The same thing happens if the WAN fails and the remote site goes into SRST. The call is preserved during failure but if the WAN comes back up during the same call, again, the call terminates right at 10 seconds of the SUB coming online. Is there a setting/timer on the gateway or within CallManager that is missing?
Here is the config for the remote gateway:
voice service voip
h323
no h225 timeout keepalive
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
dial-peer voice 7 voip
description Subscriber
destination-pattern 2...
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.1.2
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 8 voip
description Publisher
preference 1
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.1.1
no vad
Bronze
Re: H323 Gateway Call Preservation Failure
If you have IOS version 12.4 you can try to use the call preserve command that was introduced:
http://www.cisco.com/en/US/products/ps6441/products_feature_guide09186a008069ad1b.html
I also bind h323 to our loopback address, ex:
interface Loopback0
description Management Interface
ip address 10.1.29.233 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.29.233
Bronze
When configuring "call preserve", I get the following message:
Warning: Configuring media inactivity detection to avoid hung calls is highly recommended.
I've been looking through the docs on media inactivity detection, however I'm running IOS 12.4(11)T2 and the syntax seems different.
Does anybody have a working config example they could share?
 The config below is the
The config below is the config for media inactivity detection !
application
package callfeature
param med-inact-det enable
param med-inact-disc-cause 16
param med-inact-action disc
Green
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a00802b45e0.html#wp1149764
You need to enable the call preserve CLI on the router running 12.4(11)T or later and be running CM 4.1(3)sr2 or later with the call preservation service parameter enabled (Allow Peer to Preserve H.323 Calls) which is under
CallManager advanced service parameters.
Bronze
Right, so the configuration for H.323 call preservation is:
voice service voip
h323
call preserve
I also configured this:
application
package callfeature
However, I'm skeptical it's working. If I make an outbound call and then put both sides on mute, the call stays up whereas I would think the gateway detect the media inactivity and disconnect it.
1744
