08-23-2012 09:25 AM - edited 03-16-2019 12:51 PM
Hi this is my problem :
If user "a" call user "b" ( where user "b" have the Ip phone with CFWA (E164 number)) user "a" hear ringback instead of busy.
After 5 ring the user "a" hear reorder tone.
Grazie
08-23-2012 09:31 AM
If user A calls user B (has CFWDA to an external numer) User A will hear ringback from the cfwda number. Why do you expect it to hear busy?
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
08-23-2012 09:33 AM
user B is busy - sorry
08-23-2012 09:35 AM
But you said User B has a CFWD setting. SO do you have a cfwd busy setting for user B?
08-23-2012 01:26 PM
step by step:
1) user a (from mobile) call user b (CFWA to PSTN number - for example mobile number user b).
2) user b answer with mobile phone
3) user c call user b , user c hear ring back tone, but user b (mobile phone) is busy.
After 5 ring back user c hear reorder tone.
The call flow is:
(user a)pstn - > vg01 -> cucm(8.5) -> (user b)Ip phone (cfwa pstn number) -> vg02-> (mobile phone user b)pstn
A<------------_____________________call connect________________________________------------>B
C<------------_____________________ring back________________________________------------>B
thanks
M.
08-24-2012 02:02 AM
I dont see how this is a CUCM problem. CUCM forwards the call to the mobile phone. The Mobile network should send a busy signal to cucm, if the user does not have call waiting enabled on their GSM network/phone
08-28-2012 07:55 AM
Problem Details: When user dial telephone number from PSTN to phone IP registered on CUCM 8.5.(13900) call is established through gateway h323 with ISR Cisco 2821 which is connected with PSTN through ISDN PRI. If wrong number is dialed from PSTN to CUCM, the caller hear ringback tones instead voice message about inaccessibility. If number dialed is correct (ip phone registered) but it is redirect to PSTN number (CFWAll to Pstn number) the caller hear ringback always (whether user on pstn is busy or not busy).
