h323 gateway Dial-peer issue
Ayodeji Okanlawon
Guys,
I have a problem I think I have seen in the past but cant figure a way around it.
I have a gateway configured with the following dial-peer
1. Used for incoming calls from the PSTN
dial-peer voice 9998 pots
  description ** Incoming POTS Calls **
  translation-profile incoming PSTN-IN
  incoming called-number .
  direct-inward-dial
2. used  to route calls to CCM
dial-peer voice 2000 voip
  description ** Calls to LIV-CMBE **
  destination-pattern [23]...
  session target ipv4:10.53.2.10
  voice-class codec 1
  dtmf-relay h245-alphanumeric
  no vad
I also have the following ephone-dns for srst
ephone-dn  216
number 2389
  preference 1
call-forward all 7335
ephone-dn  217
number 3490
  preference 1
The problem we are having is this.
when an inbound call hit the gateway eg called number = 2389, the ephone-dn pots dial-peer is matched and beacuse SRST is not active the call fails.
The VOIP dial-peer obviuosly has a higher preference, but its the ephone-dn pots dial-peer that is been matched.
Whats the work around for this please?
Please rate all useful posts
Ayodeji Okanlawon
Never mind, I have resolved this issue.
I resolved it by changing my dial-peer hunt algorithm. The default is longest match. I changed it to use preference by using the command
dial-peer hunt 3.
This command enables the gateway to use preference to select its out going dial-peer. The default is that the gateway will use longest match and since the ephone-dn will always have longest match, hence the reason why its dial-peer is been selected/
