H323 gateway duplicate set-up calls
I have configured an H323 gateway and all incoming call receive the following -
I have attached the config, but the dial-peers seem to be matched, so l am not sure why the incoming calls fail.
Jan 26 13:02:49.176: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x2180, '1383413747'
                Plan:ISDN, Type:National
        Called Party Number i = 0x81, '427199'
                Plan:ISDN, Type:Unknown
Jan 26 13:02:49.176: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x8001 callID = 0x0061 switch = primary-net5 interface = User
Jan 26 13:02:49.176: ASSERTION FAILED : ../voip/cctsp/tsp_cdapi.c:  tsp_cdb_assert_check:  9517
Jan 26 13:02:53.156: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
        Sending Complete
                Standard = CCITT
Jan 26 13:02:53.156: ISDN Se0/0/0:15 **ERROR**: L3_GetUser_NLCB: DUPLICATE SETUP, message ignored.
Jan 26 13:02:56.328: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0001
        Cause i = 0x8090 - Normal call clearing
Jan 26 13:02:56.328: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x8001
Jan 26 13:02:56.392: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0001
FCBC-POR-R01#
Jan 26 13:04:42.400: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1383413747, Called Number=427199, Voice-Interface=0x2B675B6C,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=802
Jan 26 13:04:42.400: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
   Calling Number=1383413747, Called Number=427199, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Jan 26 13:04:42.400: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=427199, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=427199
   Result=Success(0) after DP_MATCH_DEST
Jan 26 13:04:42.400: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
Jan 26 13:04:42.400: ASSERTION FAILED : ../voip/cctsp/tsp_cdapi.c:  tsp_cdb_assert_check:  9517
James
Green
James,
Looks like you are hitting a bug
CSCsm31235
CSCsm31235 Bug Details
Inbound ISDN calls fail with **ERROR**: Module-CCPRI ...CCPCC_CallIdle.
Symptom:
Incoming ISDN calls fail with the following error after the SETUP message is received:
ISDN **ERROR**: Module-CCPRI Function-CCPCC_CallIdle Error-Unknown event received in message from L3 or Host: 90
Another SETUP may be sent by the carrier due to no response, which generates this error:
ISDN Se0/0/0:23 **ERROR**: L3_GetUser_NLCB: DUPLICATE SETUP, message ignored.
Workaround:
None
Status Status
Fixed
(Resolved)
Severity Severity
1 - catastrophic
Last Modified Last Modified
In Last Year
Product Product
Cisco IOS software
Technology Technology
1st Found-In 1st Found-in
12.4(15)T2
Known Affected Versions KAV
Fixed-In Fixed-in
12.4(15)T3
Component(s) Component
isdn
Regression http://tools.cisco.com/Support/BugToolKit/images/Field%20Definitions.html
Check IOS and up or downgrade
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Alex,
Thanks for getting back to me on this.
I had logged a TAC case at the same time of creating this on the forums. Cisco TAC advised me that they have a number of internal notes highlighting the a reboot of the ISR router was required for the H323 incoming call leg to be functional.
I scheduled a reload for that evening, and after the router was back online, l could make calls into the CUCM system.
Thanks for getting back to me.
James
1249
