h323 gateway inbound caller id pots lines
I am trying to troubleshoot an intermittent inbound calling problem.
Right now I have some debugs enabled on the router and that output is being sent to a syslog server.
The calls are all coming inbound on POTS lines.
I have caller-id enabled on the FXO ports in the router.
In the debug output is see "[2/0/12] get_fxo_caller_id:Caller ID receive failed. parseCallerIDString:no data." and also "Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)"
Is there anything else I need to do or check into to get caller id to work?
Could the caller id info be missing because the telco is not sending it?
Green
Re: h323 gateway inbound caller id pots lines
Please paste your config and the best way to do it is running debug vpm signal and debug voice ccapi inou
Right on.
Actually I am currently working with TAC on this problem while also doing so research and testing as well.
The debugs are getting sent to a syslog server and the ones currently enabled are:
H.225:
H.225 ASN1 Messages debugging is on
Voice Port Module signaling debugging is on
CCAPI:
debug voip ccapi detail is ON (filter is OFF)
debug voip ccapi inout is ON (filter is OFF)
The example showing voice-port 2/0/12 that I inlcuded in the OP is from the currently enabled debugs sent to the syslog server.
Even with caller id enabled configured on the FXO ports I still cannot see the calling party number as indicated in the OP example.
Here is the current (edited) show run:
voice-card 0
no dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice class codec 10
codec preference 1 g711ulaw
codec preference 2 g729r8
voice translation-profile prefix9
translate called 10
voice-port 2/0/0
description HRIS4 Shop Bay Phone 1 3408
station-id number 760431XXXX
voice-port 2/0/1
description HRIS4 Shop Bay Phone 2 3409
voice-port 2/0/2
description HRIS4 Fax 3420
voice-port 2/0/3
no battery-reversal
description Paging System
voice-port 2/0/12
trunk-group PSTN 5
connection plar opx 3400
description 760431XXXX
caller-id enable
voice-port 2/0/13
trunk-group PSTN 4
connection plar opx 3421
caller-id enable
voice-port 2/0/14
trunk-group PSTN 3
connection plar opx 3422
caller-id enable
voice-port 2/0/15
trunk-group PSTN 2
connection plar opx 3423
caller-id enable
voice-port 2/0/16
trunk-group PSTN 1
connection plar opx 3424
caller-id enable
voice-port 2/0/17
connection plar opx 3407
description direct line for Service 760.431.XXXX
caller-id enable
voice-port 2/0/18
connection plar opx 3420
description direct line for fax 760-431-XXXX
dspfarm profile 10 conference
description HRIS4_Conferencing
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729r8
maximum sessions 4
associate application SCCP
dial-peer voice 90 pots
trunkgroup PSTN
destination-pattern 9T
dial-peer voice 91 pots
trunkgroup PSTN
destination-pattern 91[2-9].........
forward-digits 11
dial-peer voice 92 pots
trunkgroup PSTN
destination-pattern 9[2-9]......
forward-digits 7
dial-peer voice 9911 pots
trunkgroup PSTN
destination-pattern 9911
forward-digits 3
dial-peer voice 1000 voip
destination-pattern [0-8]...
voice-class codec 10
session target ipv4:10.176.8.11
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 1001 voip
preference 1
session target ipv4:10.176.8.10
no vad
dial-peer voice 1002 voip
preference 2
session target ipv4:10.176.8.140
no vad
dial-peer voice 1003 voip
destination-pattern #T
no vad
dial-peer voice 1004 voip
preference 1
no vad
dial-peer voice 1005 voip
preference 2
no vad
dial-peer voice 1006 voip
destination-pattern 4....
no vad
dial-peer voice 1007 voip
preference 1
no vad
dial-peer voice 1008 voip
preference 2
no vad
dial-peer voice 999200 pots
description HRIS4 Shop Phone 3408
destination-pattern 3408
port 2/0/0
dial-peer voice 999201 pots
description HRIS4 Shop Phone 3409
destination-pattern 3409
port 2/0/1
dial-peer voice 999202 pots
description HRIS4 fax dial-peer for 4 digit fax
translation-profile incoming prefix9
destination-pattern 3420
port 2/0/2
dial-peer voice 999203 pots
destination-pattern #8
port 2/0/3
gateway
timer receive-rtp 600
The caller id is not showing up because the telco is not sending the data to us.
FWIW my problem has been solved so this thread can be closed.
606
