H323 Gateway International calls fails
International call fails from one of the PRI port 0/2/0, but national and GSM works fine, cause code (31) need advice from experts on CSC.
Attached are the debug output from the working PRI and non working PRI & configuration.
thanks
1 ACCEPTED SOLUTION
There is no difference
There is no difference between the working international call and non-working international call. The only difference is that non-working is on 0/2/0 while working is on 0/0/0. We are sending the same information on both the lines but it is not being accepted on 0/2/0.
Please check with the telco on what they are expecting on line 0/2/0 and why they are disconnecting the call with cause 31.
In the non-working case, the
In the non-working case, the call fails with cause 31 which is
Cause No. 31 - normal. unspecified.
This cause is used to report a normal event only when no other cause in the normal class applies.
Can you take the debug isdn q931 for the successful and failed call and also send them here?
That should give us the answer to the cause of failure.
Here are the attached,for
for success isdn call i disconnected on ringing
also attached the successful
also attached the successful connected call for working PRI
For the successful call, once
For the successful call, once you send the call to the telco, it is being routed by the telco.
Aug  5 08:45:33.771: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x4930
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98387
                Exclusive, Channel 7
        Calling Party Number i = 0x0081, '877'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '24773376'
Aug  5 08:45:33.807: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xC930
Aug  5 08:45:34.859: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xC930
        Progress Ind i = 0x8488 - In-band info or appropriate now available
The Telco is responding with Call proceeding which means the call is being routed, then an alerting. So they are reaching the number called.
However, in the non-working case, the telco is sending a disconnect. You will need to ask the telco why we are receiving a disconnect from them. Is there some information that we are not sending them?
Do we need to send a different format of digits? Or do we need to change the type of number?
Once they answer those questions or check their side, the problem should get solved.
Aug  5 08:40:43.551: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x491F
                Standard = CCITT
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Calling Party Number i = 0x0081, '080'
        Called Party Number i = 0x80, '00912223710485'
Aug  5 08:40:43.583: ISDN Se0/2/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xC91F
Aug  5 08:40:43.639: ISDN Se0/2/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xC91F
        Cause i = 0x829F - Normal, unspecified
        Facility i = 0x91A10B02017F0606040087690107
                Protocol Profile = Remote Operations Protocol
                0xA10B02017F0606040087690107
                Component = Invoke component
                         3PTY Request
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Dearyou have check  the
Dear
you have check  the successful calls that is for national .check the attached logs of sussccesful connected international calls.
calling number 772
called number 00912223710485.
thanks
 +5 from me too, OK i will
+5 from me too, OK i will check with telco and mark as correct on the post  to know others such problems are from telco.
thanks for all to contributing suggestions.
Thanks! Glad I could help :)
+5 for Sreekanth . You have
+5 for Sreekanth . You have to check with your provider how many digits you have to send or share youe configuration with him , after that check that international service enable on the line.
thanks
please rate all useful information
Hello31 cause code means
Hello
31 cause code means
Normal, unspecified
Typical scenarios include:
Normal operation
31
Reports a normal event only when no other cause in the normal class applies.
The outgoing call match the outgoing dial-peer 30 without no issues . so as suggested kindly share debug isdn q931 , with failed and success international call .
thanks
105
