I have a problem with the transport of the names via E1 Qsig enabled. Names should be packed into the facility and coded ROSE profile and ECMA.
Here is the configuration of the serial interface:
interface Serial0/1/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice voice
isdn map address .* plan isdn type national
isdn supp-service name calling ie 40 cs 0 profile ROSE operation-value-tag ECMA
isdn negotiate-bchan
isdn outgoing ie facility
isdn outgoing display-ie
isdn outgoing ie connected-number
isdn outgoing ie caller-number
isdn outgoing ie called-number
no cdp enable
I have tried to change almost every configuration option with ROSE profile which is requested on the other side. But gateway sends setups with the facility coded with profile NetworkExtension (0x9F) instead of the ROSE (0x91) selected.
Is it an IOS bug have i missed some configuration step?
IOS version Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9_IVS-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
IQ931 trace:
Aug 5 18:02:34.325: ISDN Se0/1/1:15 Q931: TX -> SETUP pd = 8 callref = 0x562A
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18381
Preferred, Channel 1
Facility i = 0x9FAA068001018201018B0100A109020215D70201008000 <--------------sended
Calling Party Number i = 0x2181, '90760140'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '9023333'
Aug 5 18:02:34.381: ISDN Se0/1/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xD62A
Channel ID i = 0xA98381
Exclusive, Channel 1
Aug 5 18:02:34.385: ISDN Se0/1/1:15 Q931: RX <- ALERTING pd = 8 callref = 0xD62A
Facility i = 0x91AA06800100820100A116020101020101800E506176656C205472756E6563656B <--------requested
Progress Ind i = 0x8088 - In-band info or appropriate now available
Aug 5 18:02:34.777: ISDN Se0/1/1:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x562A
Cause i = 0x8290 - Normal call clearing
Aug 5 18:02:34.813: ISDN Se0/1/1:15 Q931: RX <- RELEASE pd = 8 callref = 0xD62A
Aug 5 18:02:34.813: ISDN Se0/1/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x562A
Thank you for the answer.
Best regards,
Michal Levak
