Community Member
H323 gateway outbound dialing
I am trying to set up a 2911 as an h.323 gateway connected to call manager.  I have the 5 digit dialing working and inbound is working.  My problem is outboud dialing.  I receive a fast busy on the outbound call.  I'm only using one pots line at the moment.   I can see the call reaching the gateway and going out but still receive the fast busy.  Could someone please check over my config and possibly see what I'm missing?  Thanks.
version 15.1
hostname BN-USHUM01-RTR01
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool Data
network 10.32.118.0 255.255.255.0
default-router 10.32.118.1
domain-name abs.com
dns-server 172.27.10.31 172.27.10.32
ip dhcp pool Voice
network 10.32.119.0 255.255.255.0
domain-name ABS
default-router 10.32.119.1
option 150 ip 10.5.1.15
no ip domain lookup
trunk group outbound
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  no call service stop
voice class h323 1
  h225 timeout tcp establish 3
license udi pid CISCO2901/K9 sn FTX162980WB
hw-module pvdm 0/0
hw-module pvdm 0/1
username comms privilege 15 secret 4 LJjRhLQE9EeK0wxjud/EkEzZuTvRmpkVQAmfVmqtvcQ
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.32.118.1 255.255.255.0
interface GigabitEthernet0/0.2
description Voice
encapsulation dot1Q 2
ip address 10.32.119.1 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.32.119.1
interface GigabitEthernet0/1
ip address 172.27.2.10 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.27.2.222
access-list 100 permit ip host 10.32.119.4 any
access-list 100 permit ip any host 10.32.119.4
control-plane
voice-port 0/0/0
trunk-group outbound
connection plar 25425
voice-port 0/0/1
shutdown
voice-port 0/0/2
shutdown
voice-port 0/0/3
shutdown
mgcp profile default
dial-peer voice 2 voip
description Inbound 5 digit DN send to CUCM
preference 1
destination-pattern 25425
session target ipv4:10.5.1.15
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 5 pots
description Long Distance
destination-pattern 91[2-9].........
port 0/0/0
forward-digits 11
dial-peer voice 6 pots
description Local
destination-pattern 9[2-9].........
port 0/0/0
forward-digits 10
dial-peer voice 7 pots
description International
destination-pattern 9011T
port 0/0/0
prefix 011
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
port 0/0/0
gateway
timer receive-rtp 1200
gatekeeper
no shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
You need to post a debug ISDN q931 to see why the call it's failing.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Silver
Since he's using FXO, he will need to use debug voice ccapi inout.
Hall of Fame Super Silver
Also, provide "debug vpm signal", are you sure you have loop start POTS lines and not ground start? Try changing to ground start and reverse polarity if still having issues.
Chris
Community Member
Debug vpm comes back with nothing.  Looks like I"m not reaching the port.  I did find that the toll fraud app was stopping it at first.  Now I get a recording saying the call cannot be completed as dialed.
BN-USHUM01-RTR01#
Aug 13 15:47:11.486: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
Aug 13 15:47:14.270: //-1/0001E1421700/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Houma Main Line
   ----- ccCallInfo IE subfields -----
   cisco-ani=25425
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=12813867708
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Aug 13 15:47:14.270: //-1/0001E1421700/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x30B3AE2C, Call Info(
   Calling Number=25425,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=12813867708(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=2, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=42
Aug 13 15:47:14.270: //-1/0001E1421700/CCAPI/ccCheckClipClir:
   In: Calling Number=25425(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=25425(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
Aug 13 15:47:14.270: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 13 15:47:14.270: :cc_get_feature_vsa malloc success
Aug 13 15:47:14.270:  cc_get_feature_vsa count is 1
Aug 13 15:47:14.270: :FEATURE_VSA attributes are: feature_name:0,feature_time:809807304,feature_id:42
Aug 13 15:47:14.270: //42/0001E1421700/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=25425(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=12813867708(TON=Unknown, NPI=Unknown))
Aug 13 15:47:14.270: //42/0001E1421700/CCAPI/cc_process_call_setup_ind:
   Event=0xC0DF7060
Aug 13 15:47:14.270: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 12813867708
Aug 13 15:47:14.270: //42/0001E1421700/CCAPI/ccCallSetContext:
   Context=0x410A09B4
   >>>>CCAPI handed cid 42 with tag 2 to app "_ManagedAppProcess_Default"
Aug 13 15:47:14.270: //42/0001E1421700/CCAPI/ccCallProceeding:
Aug 13 15:47:14.274: //42/0001E1421700/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Aug 13 15:47:14.274: //42/0001E1421700/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Aug 13 15:47:14.274: //42/0001E1421700/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30B3AE2C, Tag=0x0, Call Id=42,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Aug 13 15:47:14.274: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 13 15:47:14.274: :cc_free_feature_vsa freeing 3044ADC0
Aug 13 15:47:14.274:  vsacount in free is 0
BN-USHUM01-RTR01#
Silver
Your outbound dial-peers are not matching as you are not sending the prefixed 9.  Either send the 9 from CUCM or remove the 9 prefix from each of your outbound dial-peers.
Could you put a "show dial-peer voice summary"
try to remove the trunk-gproup
voice-port 0/0/0
and  add
description Local
port 0/0/0
forward-digits 10
no register e164
and put this command to verify if the local numer is routed to correct dial-peer
sh dialplan number 95554554455
regards
Community Member
Thanks, the dialpeer is what was getting me.  Chaned the predot in the call manager to none and all is working.
1404
