H323 gateway reoder tone
I have CUCM version 6 running in standard configuration with a h.323 gateway connecting to Nortel PABX. When I make a call from an IP phone through the PABX to a PABX phone or a PSTN phone (which connects through the PABX) the call connects fine but when either party hangs up I get a re-order engaged tone .
Any ideas.
Re: H323 gateway reoder tone
What interface did you use for your integration with Nortel?
We are using a E1 with QSIG signaling . Here is some of the config.
voice call disc-pi-off
voice call convert-discpi-to-prog
voice rtp send-recv
voice service pots
voice service voip
signaling forward unconditional
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
ontroller E1 0/0/0
pri-group timeslots 1-31
description Nortel B15
controller E1 0/0/1
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-qsig
isdn timer T203 30000
isdn timer T310 60000
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice voice
no isdn T309-enable
no cdp enable
Config looks good, but i am not sure but did you try providing clocking on your E1 interfaces.
Can you post a call that fails to disconnnect while running the following debug on the gateway?
debug isdn q931
129
