H323 Gateway seize POTS line
Our customer has an H323 gateway with 1 POTS line plugged into an FXO port. The POTS line will be used for 911 calls, but customer would also like to use it for SRST calls. Is there anyway to allow SRST calls on the line, but if a 911 call is made, the line is seized, any ongoing call is dropped and the 911 call goes through?
Re: H323 Gateway seize POTS line
Does the Urgent Priority check box on the Route Pattern take care of this?
I don't think so. I'm guessing, if it's possible, it needs to be setup on the Voice Gateway either on the voice-port itself or through a dial peer.
217
