H323 Gateways or CCME dial-peers
Hello everyone --
We have deployed numerous CCMEs in the past , most using FXO ports. In order to be customer friendly, we would create a number of dial-peers for each local area code with a preference for each port. For example:
dial-peer voice 1000 pots
destination-pattern 9407.......
port 0/1/0
forward-digits 10
dial-peer voice 1001 pots
preference 1
port 0/1/1
forward-digits 10
dial-peer voice 1002 pots
preference 2
port 0/1/2
forward-digits 10
dial-peer voice 1003 pots
preference 3
port 0/1/3
forward-digits 10
dial-peer voice 1100 pots
destination-pattern 9321.......
port 0/1/0
forward-digits 10
dial-peer voice 1101 pots
preference 1
port 0/1/1
forward-digits 10
dial-peer voice 1102 pots
preference 2
port 0/1/2
forward-digits 10
dial-peer voice 1103 pots
preference 3
port 0/1/3
forward-digits 10
Once you add on long distance and 911 this can be a management headache. We have also tried using 9T with a 2 sec Interdigit timeout, but customers give us grief about that, and we still have to create dial peers for X11 and long distance.
What do you guys do? Is there a cleaner method of creating dial-peers.
Thank you.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: H323 Gateways or CCME dial-peers
Absolutely, trunk groups is the solution.
1 - associate the pots line to a trunkgroup:
voice-port x/y (or int x/y for ISDN port)
trunk-group
2 - in the dial-peer, use it instead of port:
dial-peer voice XX pots
trunkgroup
3 - optionally, define preference for the individual port inside the trunk-group in step 1
4 - optionally, define multiple trunkgroups with preference in step 2
5 - optionally, define an hunt-scheme for the trunkgroup:
trunk group
hunt-scheme least-used
Hope this helps, if so please rate post!
trunk-group
trunkgroup
trunk group
Very cool, this is what I needed.
Thank you.
Thank you for the nice rating and good luck!
117
