H323 GW and viking door controller
Trying to activate door lock release through phone using CM 4.1 in h323.
i can answer the phone when user activates door phone but when I
try pressing ** which is code for triggering door release the cisco phone
will just disconnect. This is using an fxo port and the DPs I believe are correct.
If I disconnect from the gateway and test it with my butt set it does work. anyone have any ideas?
250
