Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
H323 GW intermittently transmits ISDN resource unavailable
I have an H323 voice GW which connected to the PSTN via a T-1 PRI. Intermittently, callers from the IP telephony network receive re-order tone when dialing out.
Debug ISDN q931 indicates GW sending to PSTN that network resources are unavailable:
ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x1AFE
Cause i = 0x80AF - Resource unavailable, unspecified
"Show isdn serv" indicates all B channels are in service. Sometimes when this happens, there are only 3 active calls, other times there are 5 or 6 active calls.
Are there any ideas? I appreciate any input! Thanks.
Mike.
Silver
Re: H323 GW intermittently transmits ISDN resource unavailable
How is your DSP utilisation and capacity?
Possibly turn on some DSP debugs?
Cheers,
Tim.
Tim,
I do have sufficient DSPs to support/build the 24 ds0 channels and all the physical interfaces in the router. I am not doing any transcoding, CFR or MTPs. Therefore, I thought if I had sufficient DSPs to support my hardware interfaces and all DS0s on my PRI, DSPs would not be an issue. I will try some DSP debugs though. Thanks.
Mike.
Hall of Fame Super Gold
All B channels in use with only 3 active calls is a positive sign of trouble, possibly independent of DSP issue, one would need to collect debug isdn 1931 and some call debug to see why the channels are not released, before attempting dialing out.
Below is the entire ISDN Q931 debug:
If I hang up and immediately call again, it goes through.
30064771072w17179869184d: ISDN Se0/1/0:23 Q931: pak_private_number: Invalid type
/plan 0x0 0x0 may be overriden; sw-type 2
30064771072w17179869184d: ISDN Se0/1/0:23 Q931: Applying typeplan for sw-type 0x
2 is 0x2 0x1, Calling num 2396019000
4w5d: ISDN Se0/1/0:23 Q931: Applying typeplan for sw-type 0x2 is 0x2 0x1, Called
num 5182482561
4w5d: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x1AF2
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Net Specific Fac i = 0x00E3
Calling Party Number i = 0x2181, '6176019000'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '5182482561'
4w5d: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x9AF2
Channel ID i = 0xE9808397
Exclusive, Interface 0, Channel 23
4w5d: ISDN Se0/1/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x9AF2
Progress Ind i = 0x8388 - In-band info or appropriate now available
4w5d: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x1AF2
4w5d: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x9AF2
4w5d: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x1AF2
AGAIN, Another failure:
NFL-2801-1#
num 5182482561
4w5d: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x1B3F
Standard = CCITT
Channel ID i = 0xA98396
Exclusive, Channel 22
NFL-2801-1# i = 0x2181, '6176019000'
4w5d: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x9B3F
Channel ID i = 0xE9808396
Exclusive, Interface 0, Channel 22
4w5d: ISDN Se0/1/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x9B3F
4w5d: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x1B3F
4w5d: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x9B3F
4w5d: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x1B3F
NFL-2801-1#
Yes, as you capture the inconsistency in the channels used, that is something the tac has to look at. I would check the IOS to be at latest maintenance, and upgrade for completeness if needed.
Thanks Paolo for the input. I'll do a TAC ticket. Thanks again. Mike.
Do you have any updates to this issue? I have the same problem.
Well, that in itself is interesting! To answer your question..no. We are running 12.4(9)T1 in this GW and a couple others but this is the only one having the issue. I do have a case open with TAC and am running with it. We are in the debug/CCM trace stage and will keep you aprised of the situation.
Have you got a case id? I'm facing this problem in remote branches with h323-fast start enabled.
HI MIKE
Do you resolve the issue Cause i = 0x80AF - Resource unavailable, unspecified?.
Because I?m facing the same problem.
Regards.
Walter
Hi Mike,
If you solve this issue..
could you please guide me through it..
i am facing the same problem..
Thanks in advance
Tom
Regards.
Because I'm facing the same problem.
What I see, that this happens just to mobile phone numbers.
Peter
Some things to check:
'show voice dsp group all'
At the bottom, it will show 'DSP Allocation Failures:'
If this is a number higher than 0, you do not have enough DSPs.
Unfortunately, there are a lot of odd situations that cause this error message and it becomes hard to distinctly classify them. Sometimes it's a lack of MTP/transcoding resources, codec problems, DSP allocation problems, bad DSPs, bad voice ports, and some other problems.
It is very important that you note that you are TX -> the Disconnect with Resource Unavailable as it is common to receive this error message as well from PBXs and providers.
hth,
nick
Hi all, does anybody has got the solution with this, I am running same issue with
2951 with E1 QSIG....
Gustavo
CSCsx67255
Leonardo Oliveira www.avvid.net "Scientia potentia est"
1728
